Peter - Nice measuring amp! Thanks for the write-up. However, I'm a little puzzled by the output from your spec an. What causes the LF noise (<1-ish kHz) to be 15 dB higher than the HF noise? I would expect 1/f noise to have a slope to it, but in your case, it's more of a shelf.
Are the spikes around the carrier frequency and 2nd harmonic IMD products of the power supply ripple?
~Tom
~Tom
Interesting, the particular people who have jumped on this project. Pete really HAS designed an Engineer's Amplifier.
I jumped in on this too, but I work in civil engineering, and I'm actually only an engineering technician... does that count?
If memory serves, 0.75".
Thanks SY. I picked up a few tubes and sockets at the local vendor today. He was asking what the 7-pin circle dia. was. I guess that there are 7-pin sockets with different pin circle diameters. Fortunately, the four I purchased measure 0.75" across the pins.
Jeff
I got mine today too. The *%#&ing postman stuffed the envelope in the black mailbox (no it didn't fit, so he made it fit) so it spent about 4 hours bent in the sun baked mailbox. The board now has about 3/8 inch of warp in it. There are plenty of mounting holes to straighten it out.
Yes, they measure 3/4 inch. No, the sockets that I have don't fit. Yes, they can be persuaded to fit. The 12 pin sockets that I have are plastic. I wonder how long it will take for me to melt them!
Observations:
I do have some Panasonic 47uF 500 Volt caps that fit the board. Digikey part number P7442-ND, I only have two so I guess I 'll be ordering some more.
The green screw terminals that I use on the Simple SE and Simple P-P don't quite fit, but in some cases like the input connections they can ** persuaded to fit.
The leads from some monster 300 watt mosfets that I got on sale (TO-247 package) don't fit the holes in the board. Do not force things into plated through holes.
Could someone please tell me what the 7-pin circle diameter measures on the PCB.
Observations:
Well, I'm a polymer chemist. But I've fooled people into thinking I'm an engineer...
You've just reminded me of a classic flic: The Man In The White Suit, staring Alec Guinness.
Jeff
Jeff
Loved all of those Guinness Rank comedies.
Wrong. I've fooled myself thinking that you are a MS EE.
Digi-Key doesn't stock the Fairchild FQPF8N60C (Q1,Q2), but they do have the FQPF8N80C. Other than the higher voltage rating, the 80C looks pretty close in specs to the 60C.
Ok to make this substitution?
Thanks,
Jeff
Mouser has them in stock (at the moment.)
I've shared my Mouser project BOM. As of this writing I've left out the chassis mounted parts. The capacitors appear to be back ordered for now, but it shouldn't be hard to find alternates if in a hurry.
Perhaps someone may wish to share an alternates BOM.
I've been looking for somewhere to use this SCR heatsink -- it is reminiscent of some Norsk invader, or distant relative of Siegfried:
I'm going to be ordering all the pcb parts from digikey.
Jeff
Good idea! If mounted instead of an original one it will be much more effective than in the original design, even though not the most effective, according to fin orientation for convection flow.
- Tubes / Valves
- Posted new P-P power amp design
