Possible to build speakers that are => Paradigm Studio 100's for less than $1000?
The subject says it all! I have never built speakers, but I am a competent woodworker.
I currently own a set of Paradigm Studio 100's. I now want to build a set of my own speakers, and if I can do it after selling the 100's then I would be in good shape with my wife. :)
I would prefer to work off of a set of known good plans since I'm not smart enough (yet?) to design my own.
Thank you very much for your advice.
Gene
diyAudio Member
Joined 2004
I've never heard the Paradigm Studio 100's so can't really suggest something that would sound similar in DIY land. However there's a number of highly respected designs that you could look into.
I'm guessing you'll be wanting a fair old whack of bass since the Studio 100's come able equipped here:
Personally with a $1000 budget I'd go for the most quality and worry about quantity later on. This would mean a 2 way but without knowing your room size and listening habits that might be a bad choice.
Any if you look over these sites, I'm sure you'll find something that sounds interesting:
http://www.zaphaudio.com/
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
http://www.humblehomemadehifi.com/
If you are looking for lots of bass but good quality bass at that then you could just squeeze in a pair of these Dayton RS 3-way for $1000:
http://htguide.com/forum/showpost.php4?p=203855&postcount=537
Thank you for the reply.
A two way speaker, does that mean only two driven elements or just two a mid and a tweeter?
I have a decent powered sub (Paradigm Servo 15) that provides more bass than my room (and wife) can tolerate.
My listening area is 15' x 18', but the left side of the room opens up into the kitchen and dining room.
I listen to a 50/50 mix of music and movies. I like it loud, but I do not like to sacrifice quality at any listening level.
I once heard a set of Wilson Audio Alexandria's in a store in Colorado. That is what I want, but for $1000. :) Kidding...
I can increase my budget over $1000 if necessary. I would like to stay within what I could sell my 100's for (guessing $1800). This budget is just for speakers, crossovers and whatever else I'll need. I already have a decent stock of wood etc.
Thanks again for the help!
Gene
Re: Possible to build speakers that are => Paradigm Studio 100's for less than $1000?
Gene
GT
For around 1000 bucks you can kill the Paradigm 100's. In fact, if you are willing to go with something other than a wood enclosure you can probably make something as good as Wilson Watt/Puppy's and even voice it to your liking and listening room?
To keep cost low go with a standard 2 or 3 way with cost effective drivers from Vifa, Seas, Peerless or other brand like these that offer high performance/cost ratio.
The method for great sound is:
1) Carefully selected drivers; 2) good enclosure design; 3) enclosure built to higher than standard high-end quality ie, thicker walls, better bracing, more driver separation, larger cabinets for drivers, etc, 4) and a very carefully designed crossover with good parts quality.
You can built cabinet out of epoxy resin, sand and lead shot and woven fiberglass like Rockport does to make a cabinet that is better than all others but it is work intensive and somewhat more expensive than MDF and plywood.
GTHill said:
So how much (excluding cabinets) would it cost to build these?
http://www.humblehomemadehifi.com/Humble_Statement.html
I'm guessing a lot, but they sure seem to be really nice!
Gene
More than 1000 bucks. Those are very expensive Accuton drivers. Probably 1500-2000 just for the drivers not including crossovers, and other materials. Also, these kinds of exotic drivers require more filter design knowledge since they have really bad sounding resonances out of the intended listening band that have to be dealt with.
For a first time project stick to paper and polycone woofers and mid/bass drivers and silk or linen dome tweeters. They are more forgiving
Re: Re: Possible to build speakers that are => Paradigm Studio 100's for less than $1
Could you direct me to some resources for cabinet design of this type? Since I already have decent speakers I'm not in a hurry so learning a new construction technique would be lots of fun. It would also give me some time to save up for some really good drivers and crossovers.
Thank you very much for your help!
Gene
Picture of the composite panel construction:
It is simply a fiberglass epoxy skin on both sides with a high dampening epoxy foam core.
Speaker bases can be made with sand or lead shot filled epoxy to create high mass bases for the speaker cabinet.
Getting the right foam consistency will be the biggest trick for optimum stiffness and dampening.
I am in the process of designing and building a 3 way 4 driver system based on this speaker shape with drivers that I have had laying around for some time begging to be used. The speaker is a Sony ES SS m9. Perhaps the best budget high end speaker ever made. If I make a MDF cabinet it will look similar to the picture without the supertweeter. The epoxy composite cabinet I have in mind has a few changes for better diffraction characteristics around the top front edge.
frugal-phile™
Joined 2001
Not my cuo of tea, but for your extended budget you could do Thors (fat, short, or small, nit the originals, Joe blew the design on those)
http://www.diyaudio.com/forums/showthread.php?s=&threadid=64799
http://www.diyaudio.com/forums/showthread.php?s=&threadid=99596
http://www.diyaudio.com/forums/showthread.php?s=&threadid=97790
http://www.diyaudio.com/forums/showthread.php?s=&threadid=82160
http://www.diyaudio.com/forums/showthread.php?s=&threadid=70862
If i had a grand to spend on a new set of speakers i'd be using some favours to get a pair of the limited edition Fostex FE138eSR from Japan and then design a box around them
dave
