Possible Parallel the AD1955??
multiamping with digital crossover is another method to "split/combine" DAC outputs for increased linearity
the digital crossover divides the source into limited frequency bands appropriate for each driver
driver sensitivity padding can be done in analog by tweaking each driver's amplifier gain
in each band the noise bandwidth is lower and allows reducing signal level re full scale in the DAC which can reduce the distortion from smooth nonlinearities like SiO2 Vcoeff, internal amp or resistor nonlinearity internal to the DAC
the bandlimited signal in each DAC also has fewer components to interact to cause IMD and some of the harmonic and IMD distortion componets will be outside the driver audio bandwidth
the above advantages are likely enough for the sub/woofer/mid channels, only the tweeter DAC would need multiple DACs
Disabled Account
Joined 2006
Originally posted by SunRa
what do you think about the way accuphase is paralleling the chips? (the new method)
Uh, that's DSD, not PCM.
Sure, but you can do that with an analog crossover as well.
In a multi-amped setup, you can use a passive analog line-level crossover such as this and end up with the same result.
The restricted bandwidth would provide benefits as you describe, but I don't think it would overtake the benefits of using the same number of DACs together in a full-band setup, unless they were optimized for specific bands--in silicon.
There are a number of ways to introduce that delay without resorting to higher frequency clocks. For example, the AD9510 and the Xilinx clock manager block.
If you are performing linear interpolation on a PCM datastream, you will not need a clock frequency higher than the native bit rate.
Good to know, thank you.
Good you please guide me to some articles/books/something in regard to paralleling tehniques or basic digital signal processing ? I really want to understand these things better.
Disabled Account
Joined 2006
Looking at the 9510, the delay linearity is half LSB of the 5 bit setting, so 1/64 which for the 10 ns max range is over 0.15 ns. That's much worse than the clock jitter even!
Moreover, the limit from the clock jitter remains, from the end of one set of staggered delay pulses triggered by a clock edge to the next.
I haven't thought this through, but is there a reason that a funky combination of flip-flops couldn't delay the signal to each dac by any multiple of single bit-clock cycles? At 44.1kHz (with a 64*fs bit-clock), that would be 1/2,822,400th of a second. If you've oversampled to 88.2kHz, then a single bit-clock delay is the same as the Accuphase.
Just an idea.
