PMC, Bryston and White Noise Audio for sale
PMC and Bryston
PMC MB2-P oak + custom built partington stands
New cost £8700, asking £4750 for the pair.
2 * Bryston 7b-st monoblocks
New cost £3000 each, asking £1250 each
2 * Bryston 4b-st stereo amps
New cost £2750 each, asking £1250 each
2 * XBD-2-A Active subwoofers (doesnt include amps or crossover)
New cost £3250 each, asking £1500 each
Prices taken from http://www.cornflake.co.uk/pricelists/shop.pdf
White Noise Audio phono stage
Assembled by Dr White himself and including the cascode PSU - based on the audiophile variant of the circuit but further modifed again. Easily beats the Tom Evans The Groove I owned before.
Selling due to purchase of Django tvc preamp after upgrade to active from tri-amped system. The phono has an opamp based output stage which is fine into an active pre but isnt sufficient for a passive. Cost to buy would be around £900 - I am offering for £450.
Modifications:
Captive input and output leads using high quality neutric connectors and cable. Option to attach non-captive cables.
All opa chips replaced with AD8067 and AD847 - milspec where possible and on custom built adapters at additional cost. Vast improvement in sound. Some additional tweaking to support this.
All monolithic regs replaced with capacitive multipliers.
High quality screened dc cables.
White Noise Audio Preamp
Two box preamp unit for sale. The first contains a exceptionally high quality 6-way single ended switch and a captive lead for connecting to the second box that contains a high quality 24 step balanced welwyn stepped attenuator and the new WNA Mk 3 buffer amp with high performance AD8065 opamps fitted. This second box has a single unbalanced input and three pairs of balanced outputs. Ideal for bi or tri-amping. Comes with cascode PSU.
New cost around £900 assembled by Dr White himself. Looking for £450. Easily beat the TEAD "The Vibe" with Pulse PSU.
