jpfastre said:
hi Guido
Thank you for your offer but the fault is repaired.
It was an invisible print crack between R176 and C176.
JP
Hi JP,
Good to hear it works fine !
Was this crack in the PCB trace ?
jpfastre said:
Hi Guido
Yes but not visible.
Kind regards
JP
Hello JP,
Sorry to hear about that. Do you have gold plated or silver imersion PCBs ?
best
Hi Guido
It is the silver imersion PCB.
Kind regards.
JP
Joseph K said:Jp,
Congratulations! Don't forget that it was You who found it in the first place..
Hope You will enjoy your Dac as much as I do.
And I think Guido's analysis was spot on..
Ciao, George
Hello Jean Pierre
Great you found it - will check PCB's and discuss with board manufacturer. Hundreds have been build, and they all run, except one in Mexico, where very (out of spec) high mains voltage killed some elctrolytic caps
best
- Digital Source
- PLL doesn't lock in Tentlabs DAC
