Plate choke on a line stage?
Administrator
Joined 2004
Poobah,
Bet you got quite a "bite" from high voltage now & again! (arrrgh, forgive me).
Joe, things were so tough here that I used to hold a pen while someone pulled the paper by as I grabbed the test point. That 'scope was a big step forward as only one person was needed to troubleshoot. Not counting the guy pedalling the generator. :clown:
It's a pretty cool item for sure. As I said, a 1" tube. Nor even a flat screen.
-Chris
You actually had a guy to pedal the generator? I used to have to multitask.
Let's up this thread to let you know that...
the prototipe of my preamplifier is finished!!! Hurrà! :D
Now it has a phono section with an ECC83 and an ECC88, this last tube choiche is done to drive the volume pot with a lowish impedance. Then there's a volume pot, then there's a ECC88 CF with a 2-transistor CCS on the cathode. Very very very good sound.
Now I've got to make the definitive building...
