Ping Sy: LED for Cathode Bias
I simply put the zeners in place of Rk. I strung together 6 zeners for 33.6V. At 120mA this was going to give a little more than 2/3W dissipation per device. This would be OK for my 1W devices, but I like to give zeners a little room, hence the second string in parallel.
The zener string's cathode goes to the triodes cathode and the anode goes to ground. The bypass cap is connected like a typical CRk. Without the cap, the amp is quite useable but it has a little background hash, and a few small pops and crackles from time to time.
I use a Wima MKP at present and it does well. I plan to play with maybe a larger value film and a small low esr bypass, but I've been too busy listening :D
There was some talk on another thread about wrapping the zener with a transistor. I don't have access to it at the minute and haven't tried it yet but will post if interested.
Ryssen said:
Yes,but I wonder if noise will be higher on LED´s with just 7mA trough them,or if the minimum usable is 10mA?
Even with the highest gain triodes (CCS loaded 6C45PE @ ~4 Vdc on the cathode, 5 ma current) series LEDs never brought the noise floor above the 24-bit limit of my test kit, about 130 dB below 1 volt. I can't see how LEDs could inject enough noise into the cathode of a tube with a quarter the gain like a 76 to approach the limits of any contemporary audio storage system.
Here's an excerpt from Morgan Jones' 'Valve Amplifiers' third edition about LED forward drop at 10mA (! coincidence?) and typical Ra:
cheap red led = 1.7V @ 4.3ohms
cheap yellow yellow/green led = 2.0V @ 10ohms
true green led (525nm) = 3.6V @ 30ohms
blue led (426nm) = 3.7V @ 26ohms
ez81 and ez80 diodes are also featured but have much higher Ra (about 200 and 500ohms)
Simon
