Family portrait propably rework cases later..once again.
What are they?
What are they?
Aleph 5 clone - monos on bottom and Amp camp camp (not so ready yet, waiting for 4 more capacitors to arrive). Alephs will drive JBL 2225 and ACA JBL 2445 + horns.
My F5 decided to turn into an F5 turbo overnight.
Hikari1:
I'm curious: is there an advantage to using so may bypass caps in your F5T's power supply, and what value did you settle on?
Scott
Here is my dual mono F5 Turbo V2.
Hope you like it. I moved it to the floor since the picture was taken.
The only thing i'm a bit unsure of is the placement of the positive output cable although it doesn't seem to have any negative effect, it looks sort of strange.
why 4 transformers?
why 4 transformers?
Needed them for the right specs. They are 1x24 volt 300VA
So connected two for 2x24 and double up for the two channels.
- Pictures of your diy Pass amplifier
