tubee said:What's the big secret about the CD7? How are the dacs feeded, differential? And I/V, Marantz like with Hdam's? If so it can be done diy too
Digital
VAM1252 -> SAA7372 -> 74HC257 -> DSP56004 -> 2x TDA1541A/S2
TDA1315 -> SM5844 -> 74HC257
Analogue
3x HDAM per channel. Two for the balanced output and for single ended.
cartman said:Hi rfbrw!
If I use the CD7 in normal CD mode (44.1kHz 16bit), is the signal skips the DSP56004???
No. The 74HC257 is used to switch between the CD and the incoming SPDIF stream.
Which is the IC what divides the digital signal to L & R channel??
Thx!
The second DSP56004.
Thanks rfbrw!
What is the recommemded upgarde for CD7?
The clock?
Which freq.?
What is the exact CDM type in CD7?
VAU1254/21 or /31? (like in the CD-Pro2M)
Have you the serivice manual?
My cd7 is "only" less than 3 yrs, but I'd like to stock one CDM for spare for the future
Thx in advance!
The clock?
Which freq.?
Thx in advance!
No idea.
The clock?
Which freq.?
33.8688 MHz
and
36.8640 MHz
VAM1252
Somewhere.
rfbrw said:
33.8688 MHz
and
36.8640 MHz
2 different clocks... the upgarde isn't simple
We're producing the VAM1254 & VAU1254 now in Hungary...VAM1252
What is the difference between VAM1252 and VAM1254
I think not too much...
If you found it, can you share with me?Somewhere.
Thx in advance!
Thanks tbla!
are you sure?
what is the function of these caps?
just the DC decoupling (for safety)?
rfbrw! What do you think?
tbla said:remove/short those......
are you sure?
Thanks Guys!
I will check the DC presence, casue my "pre-amp" is a passive ladder network without any decoupling caps, and my power amp is a JE Labs 300B without any caps at input also...
I hope, the designer of CD7's buffer was a genius, and these caps are just for SAFETY...
I own a CD-7 and modded some. There is DC for sure!!!! On XLR there is .5v DC. I replaced with Mundorf Silver/Oil 1µF (high impedance on integrated amp, so low value cap did it for me).
I changed the clock (only the 33.xxxx one) with a TentX02 feeded by XO supply. Nothing with Black gates or schottkey's yet.
There is a huge difference between VAM1252/00 and VAM1254/01.
Different chip (CD-7 laser uses TDA1302T) and pin config of flatcable is different.
I am corresponding with a German Dude. Possibly found a laser replacement (laser assembly is self-adjusting, so would be snap-in replacement).
- Digital Source
- Picture of Marantz CD7 with Double Crown
