Picture of DCD1500 inside
rfbrw said:
Sony, hence the 3 dacs suggested.
I tried to use a TDA1543A DAC without disconnecting the digital filter SM5801. The result was a sound with a lot of noise. I did not want to cut the connection of SM5801 without first trying to improve the sound with the original PCM54 DAC.
I then decided to disconnect the low quality metal can low pass filters and replace them with a pair of good quality TRW 2.2 uF polypropylene caps. BINGO!!!!! The sound is very very good now. It is amazing how a small change can improve the sound so much. You DCD1500 owners out there, please try it and you will like it.
