physical hum reduction in class A amps
Joined 2010
Hey all,
I've an ongoing fight with pretty much anything I've built with hum (there's an aleph clone winking at me from here with that issue). And i tripped over the below whilst browsing about today. I appreciate the solution presented is to transfo hum, but smoothing that sawtooth in the rails cant hurt anything right?
It's a cheap part to add, so I got to wondering why it's not a common solution I've seen here. why would I not add this to every build I do? I do use the usual CRC psu anyway, but this seems quite a easy add on?
Thoughts?
PS part in question (i think) http://www.altronics.com.au/p/l6630-470uh-5a-high-frequency-inductor-choke/
PPS: ...i use 300VA transfos at a minimum for pass builds. The 160VA below feels ...optimistic
adding coil/inductor or a resistor between the first stage and second stage of the smoothing creating a Pi filter gives a BIG improvement.
The Pi filter helps to reduce the fundamental. But it makes a much BIGGER improvement in attenuating the higher harmonics.
The saw tooth waveform of a simple rC filter becomes nearly a low amplitude sine wave on your DC when you use an rC (R+L) C Pi style filter.
It's the removal of the very high harmonics that often pass straight through the amplifier that gives the main improvement in sound quality.
