Photo Gallery
Those OPTs look OK but I'm reading less than 1K across the primary! Click on the web link in post 1 for the schematic. Very simple, does sound sweet though, considering it has to beat it's way through those transfos!
BTW - in deference to another thread, "yes Virginia there is an iso transformer in there." Actually 2 of them, I sneaked 100V by doing 120V to 15V fed back into the 17V secondry of #2 and back out the primary, made about 105V for less than $7!
PB
Can you explain the use of OC2 on the ECC82 cathode?
The circuit is based on the loftin-white theme. Because the grid of the output tube is directly connected to the plate of the driver, this must be about 14 volts negative to the output tube's cathode in order to bias the output tube correctly.
This is usually done by using a large cathode resistor on the output tube but I thought that a 150v regulator tube would generate less heat and look cool.
It seems to work ok but the 0C2 can only cope with 30ma max so this design couldn't be scaled up.
There might also be difficulties with bias stability during mains fluctuations as the cathode of the ECC82 will stay fixed at 150v while the plate of the driver will vary with the ht supply. In practice nothing bad has happened so-far
planet10 said:
Have you seen mine?
http://www.t-linespeakers.org/tubes/SEP_50EH5.html
dave
Dave,
Instead of going to all that trouble to make those wee little tubes look bigger, why didn't you just use bigger tubes? 50L6? ;) Ducking for cover now. :D
Actually really did you consider 50L6? The covers you use are sometimes used to deal with microphonics. Was that an issue with your 50EH5's?
Rob
frugal-phile™
Joined 2001
This amp is a rebuild of the amp in the flip-down TT unit my parents bought when i was 12. The tube coolers are floor sweepings (rejects) from a batch i helped pack up for England -- this amp is meant to be a caricature -- the tube coolers give it more... The website link has the whole story.
dave
My new amp
Hey!
Here's my newest offspring, a winged-C 6B4G SE amp, pre-amp stage is an winged-C EF86; rectifier is a Haltron EZ80.
Still haven't heard it right, need to change the circuit a bit, first.
As usual in my amps, all the iron is custom made by Edonion
50EH5
philipbarrett said:
Here's a humble little project amongst all those super-amps!
Still awaiting real OPTs, connected to my DAW, the 50EH5 "Daddy" amp.
http://www.geocities.co.jp/Milano/1988/radio/50eh5.htm
Note external passive volume control, amp will eventually be on a shelf.
PB
Ack, another 50EH5! Good stuff.
I built mine around the original tube data notes with help from the link you shared above and Dave's http://www.t-linespeakers.org
For more info on my 50EH5, visit my website:
http://ca.geocities.com/gmilitano
Yup, your OTs look larger than mine too. My long term plan is to have them run some Radio Shack 40-1310 super tweeters.
Gio.
