Photo Gallery
Back to audio
Probably be best to keep this thread (and forum) to audio amps.
My excuse was that my little 813 amp doubles as testbox for the upcoming 813 audio amps.
To get back on topic: the power supplies are reconnected to their 300B amps so I have some music while studying.
And yes, those are parafeed :D
I like this kind or design, triode pushpull
Ah so we can post instrument amps? Here is my bass guitar amplifier:
It's basically built on top of an op-amp based parametric tone control, tight fit indeed. Power amplifier is a pushpull 6FD7. HT+ is using an SMPS that was meant for Nixie tubes to save space and cost. OPT is a power transformer with 220-110-0 primary and 0-4.5V secondary as output to speakers. Puts out around 7-8 watts. It still needs more gain so there will be a 6N23P/6N2P gain stage at the input. Quite surprised with the wide frequency range the OPT transformer is giving!
Thats a nice design, musician !
my 832 pp amp lives.....
no global negative feedback...
plate B+ is a bit high at 405 volts, screen at 180 volts...
a slight red plate after 30 minutes so i am going to lose some plate B+
i reckon, about 9 watts per plate ought to do it...
how is the sound? i like it.... ;)
this amp comes with a phono stage built in....
in all my builds i implement a central ground point
Hi guys! A while back I was asking questions on how to properly get at wiring up a preamp properly. And now with all your guys help and tips, it is now complete!
More photos and details :
Phono Pre-Amplifier
Hi woodrough,
Viewing other members constructions I came across yours, which is really nice. Actually, I am amazed by the construction.
I noticed the 5755 tubes and also read your description of the 2 mu-follower stages. I have recently built a phonodude designed by Dick Van de Merwe (triodedick) and Doede Douma which also uses 5755 tubes at input and is 2 mu-follower stage design.
Could you send me your schematic? I could possibly try some experiments with my construction!
Neurochrome.com
Joined 2009
That is absolutely gorgeous. Nice build and nice chassis layout, design. I really like the symmetry.
Excellent photography too. Softbox + reflector?
Cheers! :cheers:
~Tom
Phono Pre-Amplifier
And here is my humble phonodude implementation. Please be gentle with it, it is my first tube creation.
All metalwork is DIY, reusing side aluminium panels from abandoned lab equipment; 1.5mm for the chassis, 6.5mm for front and rear panel.
The bottom part is too short, so some components fit marginally, but I had to constrain the total construction height to 90mm (WAF related reasons included).
With the precious help from a relative greek forum (some people are around in this forum too), this project came to reality and I really enjoy it!
Still have to decide about the top/bottom covers colour and paint them, and mount them with screws.
1. Really nice construction and neat cabling
2. Are these 6Ж32Π ?
3. Beware Beware these brown plastic caps! I founds some shorted in one case.
thanks to nylon ty-wraps and square plastic mounting bases, wiring is a breeze,
but the planning takes longer...
yes, i used the 6J32 analog of the EF86, these russian tubes i have grown to respect...
i do test components before soldering them in, as a common practice, i test the amp is various stages of construction to see that the target voltages are as designed, (sometimes they were slightly off....but no big deal really)
the one thing that i am proud of in my builds is that i make all the irons used in my amps, Z11/M6 in the OPT's and M18's in the power traffo....
