Yes, especially in the bass. It is dead quit. You could even use specialized ultra low noise transistors and raise the current, say to 11mA. That is only of an advantage if you use a very low impedance moving coil.
The noise of that circuit will then be better then 0,3nV/qHz down to 10Hz. That is 9dB better then the AD797 that is advertised as ultra low noise.
I'm not good with links on this forum, so let's hope this works. Give it a try.
RIAA Noise Calculator
What happened to the spreadsheet? The link is dead. . .
- Analogue Source
- Phono cartridge noise calculator
