My KC-7 is finished, but not mounted in the player now
I'm waiting for the decoupling caps for the TDA1541, but haven't finished it's layout now too
But I think I will wait some more weeks. Now I haven't much time to take an hour or two listen to music, even less for diying...
It isn't optimal for listening tests
cd850 schematics
i've had this cd850 since new early 90's i think
time for upgrades
it uses separate phono pcb for headphones jrc4556 opamp and for audio out 2 jrc5534's
i am looking for circuit diagrams to upgrade this cdp
it still works and look near new
only after last move did i loose the original box.
please help
allan
time for upgrades
please help
allan
HI,fin
I am interested in the sch of SAA7350 and 850 transport circuit.Could you share me the 850 sch?
My email address is jmxg007@tom.com
thanks
X.G.
thanks
X.G.
I have CD850MkII too, and I made some very small modification (100nF ceramics parallel with the PSU filters). I planned to change the output muting transistors with reed relays, but without the schematics, I don't want to start it.
If anybody can send me the schematic, please!
sajti
sajti
Did anyone send you a copy ?
Not Yet. So my email address posted here, is not enable bigger files. If You have the schematic, please send it to: asajtos@pantel.hu
Many thanks: Sajti
andy2667 said:Hello,
Is the Marantz CD62 identical to Philips CD850MKII. I have a chance to get a Philis CD850 or a Marantz CD62. The CD62 is cheaper than the CD850. The CD62 is also in a better condition. If the cd62 IS A cLONE OF 850mkii, I will buy the CD62.
Andy
I have a CD62
it's very similar to the 850MKII, and different from the 850MKI
the only difference I saw between the CD62 and CD850MKII is that the headphone output has no volume control (full volume all the time, that's really baddly designed)
oh, and the CD62 looks soo nice
Manual sent, more available
Hello all,
I sent the CD850 manual to asajtos@pantel.hu and the guy with the @tom.com address. I have some more available, a.o. CD880, Marantz CD43...CD63 manual. It is a 9mb download...
Regards, AudioGuy.
Hello all,
Regards, AudioGuy.
X.G. said:HI,fin
thanks
X.G.
I had got the manual.Thanks,the kind man
CD850s are everwhere!
with the amount of interest in the cd850 series
anyone like to share suggestions, experiences good or bad, views
someone may have found a new idea or limitation.
I have just changed opamp so far, undecided which reclock to use,
use internal dacs or external dac system
any views
any views
HI,fin
I am interested in the sch of 850 transport circuit.Could you share me the 850 sch?
My email address is anh.chuhoang@gmail.com
thanks
thanks
Please plse plse
Can anyone send to me a copy too? to this email address:
zeropointz_04@yahoo.com.sg
anyone has any idea where the player derives its spdif output from( which chip? )?
i just got a preowned set of CD850MK2 three days ago.....the condition is marvellous for the age of the machine. Gonna use it as a transport.
I used to own a CD850 MK1.. The most bizarre upgrade was putting a rubber grommet on a crystal... I established later that this was not the the CDP clock but the clock for the FTS cct!!!!!! Damping the cdp clock crystal improved things further. I had a clock 2 trichord in mine later on.
OPA176 op amps sounded lovely and so did BYT53 diodes...
Quite sure the DC blocking caps are crappy as std.... Hoook it up with a decent mains lead and listen to the player while swapping mains polarity, the right way sounds way better then the wrong way )
- Digital Source
- philips cd850 MKII
