I think what's throwing so many folks is that the concertina has a floating output but its feedback is not symmetrical. If tested with equal and opposite currents driven into its outputs (IOW, as a concertina works) point impedances will measure equal. But if measured with equal but not opposite currents, or just single currents, driven into its outputs point impedances will not measure equal (because its no longer a concertina).
It occurs to me that, at this point, it might be a good time to distinguish between and discuss differential and common-mode output impedance.
So we have arguments about angels dancing on the heads of pins.
Exactly. That's why I used in my Pyramods a combination of Concertina and LTP. The same trick was used in some Altec - Lansing amps for cinema theaters.
It is interesting that Chris Hornbeck stated that impedance changes depending on how you test it. Perhaps that might be backwords. Doesn't it make more sense that impedance is a fixed property, and that there is a right and wrong way to test it?
I think we all need to drive toward the general definition of the impedance between arbitrary points A and B in an arbitrary circuit. The first step in coming to an agreement about Cathodyne impedances would be agreeing about the definition of impedance in general.
Does that make sense to you? Are you interested in a discussion to try to reach an agreement on such a definition?
You are very amusing. What is your background, that you are able to objectively judge the superior understanding of chemists of electronics over that of electrical engineers? Don't you find this statement odd?
My background? MS EE, Russia, Tomsk. Design and Technology of Manufacturing of Radio and Electronics Equipment. Lots of theory, plus lots of laboratory works of experimental character. We were taught to design original equipment to work in different special conditions where differences in properties literally are the question of life and death...
Tomsk was a special place: scientific institutes, real high-tech manufacturing, and educational institutes, with multiple interconnections, surrounded by deep Siberian forest. I can name only few professors who were working for education only, the rest worked as well either for science, or for manufacturing.
I believe I know why Western chemists can be better electronics engineers than Western EEs. Because chemists were trained to do experiments, while EEs were trained to copy/paste from datasheets and give links on "proper answers" in literature. In USSR it was not called higher education, it was Professional-Technical-Education, they were trained to solve always the same problems, unlike Engineers who were more like scientists here...
It is interesting that you have stated that impedance changes depending on how you test it. Please consider that that might be backwords. Doesn't it make more sense that impedance is a fixed property, and that there is a right and wrong way to test it?
There are destructive and non-destructive methods of testing. Non-destructive methods are especially designed not to change properties that are measured, by measurement tools.
I would stick to making statements about technology rather than technologists. It's more objective and less personal. Personal stuff gets in the way of truth.
I answered your direct question. If you are satisfied by my answer, let's stick together with technology. If you are not, let's stick with technology anyway.
So I unbalance the Concertina. So what?
So it's not a Concertina anymore.
And you can't apply properties of Non-Concertina to Concertina.
I said (but not to you):Originally Posted by CPaul http://www.diyaudio.com/forums/tube...9153-phase-splitter-issue-13.html#post2801690
You replied:
I'm misssing the connection between these two paragraphs.
You replied:
You answered a direct question. Then you smeared the educational background of Western EE's. (Certainly in my two MS EEs, there were lots of theory, no datasheets, and lab work.)
Yes, let's stick to technology.
Sure. Because I can smear modern Russian education the same way: it is now commercialized, so it is more like Professional - Technical Education. Invest in skills and practical knowledge, and get your job... As soon as they are obsoleted, invest in one more MS EE diploma... And so on... So, let's better stick to the technology: we discussed this "educational" topic already in the Lounge, we can continue there.
And I can't apply the properties of a non-voltage amplifier to a voltage amplifier? By that logic, I can't use the output short circuit current measurement of a voltage amplifier to determine its impedance because it's not a voltage amplifier any more.
Probably. Depending on the topology. For example, if it contains some kind of overcurrent protection you can get as the result measurement of very high dynamic resistance of overcurrent protection instead of much lover dynamic resistance of the amp when it does not protect itself from destruction.
By the way, I've found the topic about education, we can continue there if you wish: http://www.diyaudio.com/forums/lounge/188500-university-has-no-clothes.html
Not a Concertina when I measure it unbalanced. Not a voltage amplifier when I measure its output short circuit current (it's a voltage nullifier.) So what?
So I would suggest 2-point measurement technique: load both outputs by 2 equal resistors each and measure voltage drops on them, then load both outputs by equal resistors of a different value and measure, then calculate output resistances of each output. They will be equal.
I only disappeared for less than 48 hours and this thread has grown enormously! Fortunately most of it is going round in circles, as these threads do. Any analysis or measurement must maintain balance, as otherwise you are not measuring/analysing the right circuit. This includes injecting currents. The issue of feeding transmission lines is interesting, but if they are identical (same length, termination etc. - balance, again) then any reflected signal will maintain balance.
I think the issue is that the doubters keep trying to sneak in unbalance by some means or other. As I said right back at the beginning, if you take the ports one at a time you get different impedances. How can you get two different impedance measurements/calculations at the same port? Easy: by changing the impedance at the other port you have changed the circuit you are measuring/calculating at this port, so it is not the same port at all!
I am very tempted to comment on chemists vs engineers but that sort of debate has got me into trouble so I will have to remain just tempted.
There could be some variation in Miller capacitance for a triode output. This will unbalance the cathodyne.SY said:Fortunately, the loads generally seen by phase splitters do not vary dynamically!
- Tubes / Valves
- phase splitter issue
