Peerless XLS10, L-20D Modules, Sure 6x100w Module (UK)
diyAudio Member
Joined 2004
L-20D Modules, Sure 6x100w Module, SMPS (UK)
Collection from Chesterfield Derbyshire is possibility or can post.
6x L-20D Class D 200w(8 ohm) modules
New never used. These are the LJM boards. There's a huge thread in the Class D section if you want more info.
£12.50 each(mono) + postage
attachment.php
attachment.php
Sure 6x100w Class D amplifier based on TDA7498
New and boxed.
£25 + postage
attachment.php
attachment.php
attachment.php
SMPS
All PSU's are 230v input, have cooling fan installed, are CE certified and are housed in a metal casing.
36v 11A (400w) with voltage adjust pot for approx 36 +/-4v adjustment range
48v 7.8A (350w) with voltage adjust pot for approx 48 +/-5v adjustment range
60v 8.3A(500w) with voltage adjust pot for approx 60 +/-5v adjustment range
£20 each + postage
diyAudio Member
Joined 2004
All PSU's are 110-240v input, have cooling fan installed, are CE certified and are housed in a metal casing.
£20 each + postage
