PeeCeeBee
Hi!
I guess relying on VAS trannies for sonic quality was not the main consideration VAS are for current and voltage handling (stability), I believe the differential input pair plays the major role on sonic quality reproduction. IMO :)
TY!
Not the input pair itself only, the working conditions environment they're in is important. Constant input bias current is essential here, otherwise in/out subtraction is not correct and it has unavoidable integrated error.
Hi.
A thorough read through the original SSA, TSSA and VSSA threads is encouraged. This will certainly clear up all your questions/confusions about every part of this kind of amps, subjective and objective. I hope it helps you so that this thread remains a build thread.
cheers
shaan
Hi.
cheers
shaan
Exactly, I am thrilled to see more projects to arise in this thread, since creativity with individual approach is what I like here. Everywhere, to be more specific. :up:
Hi LC,
i set bias input at 2.31mA, and VAS at 11,1mA is this enough?
thank you
It's perfectly OK. VAS or TIS (as some like to name the second stage) bias will go up with temp to some 15 mA at 50°C, but that's even better if amp si pushed hard and the second stage is even more rigid.
To be more specific this 2,3 mA of input bias current is divided among Ic and feedback resistor. Actually there's 1,6 mA of input collector current through input pair.
Where did I say that only distortions will improve??? Normally both PSRR and distortions will be improved. Firmly proved that already with measuring results in the VSSA thread. Real scope pics posted to prove the difference between CCSed and non CCSed VSSA, of course in a favour to CCSed version. :yes:
You said, completely wrong and I understood that I am wrong in both of my assumptions.
P.S. If you can see any distortion on the scope screen then you are in trouble.
mmm... The thread is in trouble.
Hi dadod.
Please use the VSSA thread for discussion and teaching, like CCS etc. , everybody loves to see, read and learn. Your presence in this thread is much appreciated, as long as you stick to the topic of building yourself or help build fellow diy-ers a PeeCeeBee and it's derivatives with, maybe, a 'dadod version' of peeceebee without CCS, which will be great news for all of us.
Happy listening to all.
shaan
Hi dadod.
shaan
What I was trying to say that constant current to the input trans(if you still do this amp without ccs) will inprove PSSR but not distortion. Low PSSR could be bypassed with good power supply. I don't suggest any change to this amp just some opservations.
br dado
hullo chaps - since this is the practical part of this amplifier's development thought i can ask here- I wonder if anyone has made some measurements of the amplifier build and share their results ? I mean real world measurements and not just the sims (not that the sims are not valuable) - things like thd vs power, fft, clipping behaviour etc... i realise not everyone has the ability to do these but would be interesting if a few have.... very interesting design and thread btw...
