Hi Shaan,
I couldn't find BAV21 at Mouser and got BAV20. Is it OK ?
Answered in v4h thread PeeCeeBee V4H GB
Hi All,
sorry to stupidly ask here but I got lost in the several iterations of the amp..
Could anyone kindly link me to the latest iteration with 1 OT-pair only ? Would PCB's for that still be available ?
Thanks in advance,
Max
Post #1
PM shaan- he will either have some or can get you some, incl. laterals.
Hi All,
Thanks in advance,
Max
Hi Max.
The latest/final is Revision 2. Schematic - Rev2 Schema, and layout Rev2 Layout
I have boards, but am out of home and will be back by 10 October. I can ship afterwards.
shaan
Shaan,
I am unable to find the build thread concerning the V4 (single output pair)...
Max
This is the v4 thread, there is no separate build thread.
Can I mixed red/green leds on 1 board?
If they both show between 1.7V to 1.9V in multimeter diode test then yes.
Shaan,
could you kindly confirm I can implement the "F5"-style P3 as you suggested in the V3 thread ?
I don't expect the modified FB network to make any change in this regard, does it ?
Thanks in advance,
Max
Hi Max.
In a high global feedback amp such as v4, when you mess up the balance of AC feedback in the two halves, you get way more higher order harmonics like h6,7,8 along with lower order ones like h2,3,4 than in a low global feedback amp such as f5. To keep the higher harmonics under acceptable levels you will need to increase the bias to 1A or more and by then it has become a full fledged class A amp. If you can give it good amount of heatsinking then the asymmetry may bring up some of that "warmth" that p3 receives much praise for. However, I doubt it's worth all the effort as I did test it a year ago and found the non-p3 class AB v4 sound closer to my liking.
To unbalance the feedback, just replace one of the two 100R resistors in the feedback node with 82R or 68R(for more loss of balance).
Are the 2SK1058/2SJ162 fake?
and here is the datasheets for EXICON lateral Mosfets
http://www.exicon.info/PDFs/ecx10n20.pdf
This is a quote from Elliot SoundOne thing that is a dead giveaway as to whether a MOSFET is lateral or vertical is to compare the pinouts. Lateral MOSFETs have the source pin in the centre, while vertical types invariably have the centre pin as the drain. Many fake lateral MOSFETs are re-badged vertical devices (typically HEXFETs), so source and drain are in the wrong places and the amp will provide close to a dead short across the power supply via the intrinsic body diodes.
someone asked me if the output is inverted compared to input (as it has three stages)?
Hi.
The output is non-inverted. Input stage is inverting, VAS stage is also inverting - turning it back to non-inverting. Output stage is plain source follower type i.e. non-inverting.
Hello Shaan
here is my interpretation of your Peeceebee V4
2x24v 250va and 70000µF for each I know it's too much but I had them in the drawers!
it is true that the mod rev1 lacked bass but it had a beautiful sound image, silky and nervous at the same time
the rev2 with 47p, 220p is better it has lost nothing of its silky nervous image but with the bass and more in the face it's good and also a little too much for my ears, for my taste.
on your advice today I change 68p, 330p and I will listen like this while expecting new 47p, 220p of good cality mica to make the difference, but anyway I am happy with this new amp, even at low volune it loses nothing of its musical quality that's what I ask for a good amp
thank you Mr. Shaan, see you soon
- Group Buys
- PeeCeeBee V4 GB!
