Peavey Black Widow 18" PA subwoofer design
I'll have to look for the goo - in my pile there's two pairs of Peavey whose qes and fs are way out of spec - one pair of 15" coax, one pair of 18" - their spiders felt very stiff
1808 - it sounded ok for a home open baffle woofer with the messed up specs
Revc= 6.2040 ohms
Fs = 46.5065 Hz
Zmax= 61.6199 ohms
Ro = 19.5522 ohms
F0 = 37.9675 Hz
F1 = 56.4854 Hz
Fmin= 187.8370 Hz
Qms = 7.9149
Qes = 0.8861
Qts = 0.7969
Le = 0.8436 mH @1kHz
XLe = 10.9585 impedance @1kHz
PLe = 28.9275 phase @1kHz
k guys this is what I have mange to draw up so far using winISD, do these number make sense to anyone, if they do will it work or sound like crap.....
Driver : peavey black widow 1801-18"
Vas : 321.0
Qts : 0.61
Fs : 40.20
SPL : 0.00
Project by : Tim & Deanna
Project for : you
Number of drivers : 1
Box type : Vented
Box size : 1256.4 l
Tuning frequency : 41.00 Hz
Vent : 1 vent(s)
0.035 m length for each
0.533 x 0.609 m rectangle
Relative
Freq Gain Phase SPL
[Hz] [dB] [deg] [dB]
20.00 -22.81 304.07 29.75
25.00 -14.02 286.19 38.53
30.00 -6.32 264.53 46.23
35.00 0.69 234.74 53.24
40.00 5.92 189.66 58.47
45.00 6.87 142.63 59.43
50.00 5.76 113.29 58.31
55.00 4.66 95.61 57.21
60.00 3.83 83.59 56.38
65.00 3.21 74.66 55.77
70.00 2.74 67.66 55.29
75.00 2.37 61.97 54.92
80.00 2.07 57.22 54.63
85.00 1.83 53.20 54.39
90.00 1.63 49.73 54.18
95.00 1.46 46.71 54.01
100.00 1.32 44.05 53.87
Vas : 321.0
Qts : 0.61
Fs : 40.20
SPL : 0.00
Project for : you
Box type : Vented
Box size : 1256.4 l
Vent : 1 vent(s)
Relative
Freq Gain Phase SPL
Hi, Draw your own conclusions:
b:)
Wow ur a real hard core DIY, I tried that programs u sent me, I couldn't get it to download properly, so I tried WinISD, on this last try I had my tuning Hz at 41, I thought it was a little out to lunch with my port dimensions, so after try'n out some different Hz levels I manage to make something that seems decent, still work'n with my same box size I dropped it down to 27Hz and wow what a difference, I got 4 vents at 6" x 6" deep, and the box really came together, I think, 41Hz is good for music but being that I'm building this for my movie theater I was able to drop it down which I think will be a great improvement.
