vcelkamaja said:Hello, does anybody have one or two pieces of TI (BB) PCM 1704 for free, please ? For the DAC project I need 4 pieces but unfortunately I have only 3, received as samples from TI. I can offer some other ICs (AD1896, AD1852, CS8412, ...). Thanks.
vcelkamaja
Why don't you ask one of your friends to order additional sample for you? If not you can get it from here: http://www.digikey.com/scripts/us/dksus.dll?Criteria?Ref=37004&Cat=31523461
Re: Haven't tried the '1738s
If you have no objection to sending them abroad, how much do you want for them? I need at least 5.
ray
Jocko Homo said:Want to try some of mine??? May be a long time before I get interested enough.
Jocko
ray
SPI programming is terribly easy on the AVR. You just configure one of the GPIO ports as the SPI, enable the SPI completion interrupt, send the first byte, and send subsequent bytes on every interrupt. To configure the PCM1738 would only require six bytes:
0x12,0x22,0x13,0x04,0x14,0x10
Translated: 24-bit right-justified data format, default settings other than disabling the internal digital filter and the internal system clock generator.
For some reason the datasheet claims that de-emphasis must be enabled when the internal digital filter is bypassed. If you think that is wrong (I do), use this instead:
0x12,0x20,0x13,0x04,0x14,0x10
When I saw this thread I went and ordered the last two 1704-K's from Digikey.
However after I had placed my order, Digikey showed 76 in stock!!!
Methinks there is something fishy about the way they report their stock unless they just happened to get a new shipment of K-grade that day
http://sampo.ru/~scherbak (russian language)
On this page complete USB-DAC with PCM1738.
Controller for PCM1738 which configure digital input to I2S (nothing more).
http://sampo.ru/~scherbak/files/software.zip
http://sampo.ru/~scherbak/files/controller.ZIP
AT90S1200 (controller) can be programmed from LPT by five wires .
- Digital Source
- PCM 1704 request
