Got'cha!
I will discuss payment options in a bit
Typical lettermail postage to off the N.A. continent is ~ $12USD. However I would strongly recommend making it $14USD for Small Packet Airmail, as we've had a 50% lost-mail rate, especially to south pacific countries with oversize lettermail or ground parcel
Tuliman said:Shipping to Europe, non-EU country...? And payment?
Thank you.
Hi all,
Current count so far is:
Geek - 1
mbcouple - 1 or 2
Ryssen - 1
jleaman - 1
edjosh23 - 1
naz - 1
matjans - 1 or 2
PM650 - 1
chengtaw - 1
AndyB - 1 or 2
ipolyakov - 1
Illusus - 1
proagua - 1
curva - 1
MattN - 2
doobooloo - 1 or 2
Mike D - 1
kennylee - 1
rjkdivin - 2
A question to:
mbcouple - 1 or 2
matjans - 1 or 2
AndyB - 1 or 2
doobooloo - 1 or 2
Who wants "1" and who wants "2"? I ask this because I want to close off the first round of boards at 25, as the PCB maker wants to make them in lots of 25. So if a couple of you take 2, we can close off the first round and begin the next, with possible carryover.
Payments. I'll coordinate this too, as I have a good relationship with the PCB dude.
*passes around collection plate*
Cost of one board is $27.50 USD.
Shipping for one or two boards is to be added:
Canada (lettermail): $2.20 USD
US and US dependencies (lettermail): $3.40 USD
Rest of the world (small packet air): $14.00 USD
I accept:
- PayPal (preferred). The address is geek <at> classicvalve <dot> ca
- hyperWALLET. The address is geek <at> scorpiorising <dot> ca
- International money orders (Western Union preferred of the M.O.'s).
- Pink US Postal money orders.
- Certified cheques (Canada/US only).
Please make the paper stuff payable to and send to:
Address removed at Geek's request.
It will take around 6 to 8 weeks for you to get the boards from the time enough money is collected and the process starts, depending on how cantankerous postal and customs are.
** edit **
We need updated gerbers first though with the corrections
Geek - 1
mbcouple - 1 or 2
Ryssen - 1
jleaman - 1
edjosh23 - 1
naz - 1
matjans - 1 or 2
PM650 - 1
chengtaw - 1
AndyB - 1 or 2
ipolyakov - 1
Illusus - 1
proagua - 1
curva - 1
MattN - 2
doobooloo - 1 or 2
Mike D - 1
kennylee - 1
rjkdivin - 2
A question to:
mbcouple - 1 or 2
matjans - 1 or 2
AndyB - 1 or 2
doobooloo - 1 or 2
I accept:
** edit **
Geek said:Please do!
We'd need these for the PCB people before we go to work, so accuracy and changes before I put in the order are welcome
Well, here are the mods that have to be done...
(1) cut corner off the LM1085-3.3 (foreground) and shave transformer (background)
(2) Dremel clearance into the case for pins on the PCB:
(3) Cut a quarter inch off the volume pot shaft.
I can turn the LM1085 90 degrees which fixes (1), I'm working on (2) now. Guess you'll have to live with (3)
update:
Even if I replace the 3.2VA +3.3V/5V transformer with the 1.6VA transformer, I can't clear the case 100%. I could replace both transformers with 1.6VA units and have perfect clearance, but I fear the +-12V transformer will overheat.
You'll still need to dremel and tape as shown above, or use the 53mm high Hammond 1455N1601 case instead of the 30mm 1455L1601 case - doing this fixes all clearance problems.
new problem!
The DAC uses the Qualtek 770W-00/02 power inlet. Problem is, Digi-Key only sells these in a quantity of 100 and I can't find any places which sell in a lower quantity than that.
But it's $51.60 USD for 100, which isn't so bad. Geek, can I suggest you place an order for these and add them to the group buy?
Great!
We have a confirmed 25 right now, so I will cut off the first round here. Any more wanted, just say so and your names will be carried over for when we go to round two.
Fellas, when your sending your payments, can you also include your DIY handles here so I can mark who's paid? Some of you I know and some are obvious, but others are not so...
Gary - I'll check my wholesalers for you.
Re: Quick question.
There's a 6 pin ISP connector.
argofanatic said:I don't have Eagle installed so I can't look at the schematics.
I assume that there is an ISP and/or JTAG connector so we can (re)program the ATMega ?
If not, it would certainly be a nice to have.
Gmarsh - I've found perhaps a suitable sub?
Allied Electronics ( http://www.alliedelec.com ) part# 689-3636 or 689-3638 which is Qualtek numbers 771W-X2/02 and 770W-X2/12 respectively. They are $1.05 and $0.50 in single lot.
gmarsh said:use the 53mm high Hammond 1455N1601 case instead of the 30mm 1455L1601 case - doing this fixes all clearance problems.
I was going to put it in the 53mm case anyway...
What about the Lansing cases? Will they have similar clearance issues?
Geek -
Am I still in the confirmed 25 list? If so, do I have one or two boards reserved? I'm fine with either, especially if there will be a second batch that I can source more boards from if I decide to build a few variations.
I tried emailing you, but seems like you have it turned off. Sorry for posting this here.
- Group Buys
- PCB Group Buy for the "DAC + headphone amp" Project
