PCB for Inverted Gainclone
Please find attached PCB layout for IGC, suitable for multichannel GC poweramps. My friend Max made them, and they are cute :)
The pcb layout was designed for using ERO MKP 1841 filmcaps
http://www.vishay.com/docs/26019/mkp1841.pdf
and Caddock MP915 0,22 R at output.
1000uf's are Elna snap-in types, a bit larger than for example Panasonic FA or FC's, but those will fit also.
Both of these two circuit variations can be used:
http://ampchipdiy.com/invertedLM3875_r2_1.gif
http://home.comcast.net/~greggbaker/invertedLM3875.gif
Suitable pwr-bridge circuit/pcb could be this one:
http://www.diyaudio.com/forums/showthread.php?postid=269537#post269537
PCB was designed so that the unused pins of LM3875T should be cut of.
/Jan
  • gainclone.zip
it looks like this..
(not scale 100% when printing out, use the pdf-file in the Gainclone.zip instead).
