PASSLAB x2 preamp question
Passlasbs has release the X2 premap serivce manual in his site,but I have found a problem about the power supply,from the SCH,the The positve supply use N channel MOSFET Q1 which the type is IRFP240 and the negative use P channel MOSFET IRFP9610,the two MOSFETS with different package,but we check the PCB layout in service manual,it seams like the same package.anyone know this issue,please give you advise .
thanks
adams_leo
Nelson Pass said:
I checked, and it is an error on the schematic. Use an IRF610
if you like, although a 240 would work fine. Another case of
modifying earlier schematics on the computer - its predecessor
was an IRFP240.
:cool:
Thanks Nelson Pass,but I met a other problem about the RELAY1 and RELAY2 in power supply schematic.could you tell me the RELY driver voltage?
thanks
Leo
