Toast_Master said:would I have to change many things because changing one value would change the effects all the other components have on the crossover
Maybe but probably not.
Sometimes yes. At the least, the info you get will be good enough for the forum to help.so the actual kit may come with an instruction book saying other modifactions that you can do?
IMO this is good enough for what you want to do with it, and it is not the most important factor.Toast_Master said:Also..should siganl to noise ratio be taken into account?....is higher better?...because the altronics one is -84 Db @ 300mV
Just follow the link at my website Toasty.Toast_Master said:David Gatti could you please give me your email so I can contact you about active corssover help as well?
thanks
David
