Parts in Mumbai (India)
Am afraid to go their as they are arrogant towards ratail shopper.
Roushon.
Haaa.. Haaa.... Rightly said. I had been there when I was studying. I wanted to suscribe Elektor. and their treatment was like a dog. The owner is some chandra.... or something I don't recollect exactly. In simple words they treat you as they own shop at Pune. ( Pune shopkeepers are known for ill treating their costumers)
Roushon. i just downloaded your pdf from post no 5. Wow what a database, This has been the most selfless and most informative document i have found on diyaudio. I know few of those shops, But putting all of them together for fellowmen. It will spare long and disgusting and Frustrating agonies diyers are suffering due to lack of information on availability of electronic goods
hats off to you bro.
I will surely make a good addition to your list.
Hi Viki, thanks! But I do not deserve so much praise as
I did not write that database. Actually found it on the net
while searching and put it here for people..... It was
very helpful. I purchased a 12v motor from servo
electronics listed there for making a DIY PCB drill, they
have materials for making such a drill....
Looking forward to you additions....
Roushon
I know Precision. Am afraid to go their as they are arrogant towards ratail shopper. Nevertherless I will ask them. Tel 23640312
Roushon.
The phone number was wrong. The correct is 2386 7459.
I did call them. They have something called `silver paste
with solder content'. I tried to google, it seems this comes
in a syringe and for fine solder. Does anyone know how to
use it?
Roushon
Chromo Paper
Thanks Viki for the information. In fact I need to solder some SMD. I went to
the Lamington Road today, but shops were closed.
Toady got the address of the chromo paper dealer (attached is the scan). He
will send paper by post also. The rate is 500pieces A4 size Rs 220/-
+shipping. But I think it is best to purchase in person. The paper I have is
quite thin and that helps a lot.
Roushon.
Does any one know where to buy good aluminum chassis in Mumbai for diy amp.Other wise i was thinking of getting aluminum panels cut according to size from whole sheet.
Also good quality toroidal transformer, if any one has got it made , pls tell the rates you got it made.
Guys There is one shop SB electronics at lamington rd , He some times has good quality drivers .Last time i saw 8" sharp polypropylene drivers.looked good but without t/s specs.
As you take left from under the tunnel below flyover. The shop is just at the opposite corner of 1st right.
i want to purchase smd components does any one know any good shop.
For chassis I usually purchase aluminum sheet and then
cut suitably. It is a difficult job.
I got three toroidals made.
230v primary, 0-33v, 0-33v 5Amp per rail sec. (2pieces
Rs 4718/- (incl Tax), 2006 from radio electric, the address
in this thread)
230v primary, 15-0-15v, 15-0-15v 2Amp per rail sec. (
one piece Rs 900/- (incl Tax), 2009 from Chandratronics
again address in this thread).
The addresses are in post 3.
Both are very good.
Roushon
