Panasonic MN66271 does it take I2S from cs8414
I have good sounding Marantz CD75 with this DAC -MN66271- that I would like to use for other digital (SPDIF) players. I have receiver chip cs8414 that would convert SPDIF to EIAJ.
Do I need to program CS8414 to output EIAJ?
So what pins go where?
Thanks, if you mean SPDIF out of MN66271 then that will not be touched at all. This Marantz has digital out built in already.
So I need an advise how to connect these two chips. Pin names are different. I can see from what block to what block, but which pins?
  • CS8414.pdf
  • MN66271.pdf
