Hello Unison845,
I am in the process of building and 833A amp and noticed that your design is a lot more compact than all others out there and I am very impressed that you can use the same circuit to drive the Eimac 250TL tubes in your other amp.
I also like the simplicity of the drive circuit developed by Tubelab.com:
http://www.tubelab.com/833SE.htm
but would like to compare how your design differs from his before I embark on a full-fledged build. I am currently just building the power supplies.
Would you mind sharing the schematic?
Thanks,
-- josé k.
jose_korneluk AT bellsouth.net
Thanks,
-- josé k.
