Hello all !! New to this forum...GREETINGS from Kozhikode India.
I am planning to build a high power Amplifier using PA03 chip Package is TO3-8pin made by Apex technology, since i have a dozen of these. From the data sheet its possible to achieve 300watts/8ohms @75volts dual supply, or 600watts 4ohms @75volts dual supply.i have most of the parts and will be designing PCB shortly.
Any comments and suggestions welcome, will be posting the progress thru pictures...
sivan_and said:Test process continuing.....since last week...Running a load of 4 Ohms heater nichrome wire with a PSU of 120Volts total, Stability OK regard to DC offset..10mV>>> 22mV after 2 days stable now..
Temp on TO3 case 75deg cent....
I don't know what you've got there, but you don't have a PA-03 (your picture's too blurry to make out any numbers on the cases). The PA-03 is in a big-*** 12 pin MO-127 copper case, not an 8 pin TO-3 case. No way you're going to get 600 watts out of a TO-3.
se
sivan_and said:PA30=12 pin MO-127 copper case.
There is no PA-30. It's the PA-03 that's in the 12 pin MO-127 copper case. Not an 8 pin TO-3. If you've got 8 pin TO-3s, it's something other than a PA-03 and ain't gonna do anywhere near 600 watts.
se
Steve Eddy wrote
Apex PA30 Package: SL15 Data book volume 6 page E83.
Applications on page F108. 1000watts/4 ohms audio amp.
Data book Vol6 may be old..
There is no PA-30.
sivan_and said:Apex PA30 Package: SL15 Data book volume 6 page E83.
I'll say it's old. They're at volume 12 now. Looks like they renamed the PA-30 the PA-03.
In any case, I still don't see how you're going to manage 600 watts from an 8 pin TO-3. Oh well.
se
- Chip Amps
- PA-03 ChipAmp 600watts
