Hey guys,
Was there any thread in the past, which was comparing the performance of P3A to Leach amp?
I couldn't search, because when I tried to search for P3A VS LEACH, all sorts of results came up including either P3A or LEACH, but no Leach Vs P3A... I think the result came up around 25pages
And there cames the bombers!
No doubts!... i will keep P3A (My God!) ... uncle sam personal will be nervous now!
I will travell for some time.... gonne!
Carlos
My God, how many corn flakes visited this place?
80 people visit till yesterday.
I was slepping under the bed to avoid bombers raid at nigth!
How many of them are those crunchy corn flakes eaters.... they do not like when someone tells something against Mr Leach.
I like Mr. Leach too, unfortunattelly, i am trying to find where the deep bass is.... could not find them under the bad. (kidding, life is too serious, work hard, payments to make, beauty spanish wife disturbing me a lot... this way i try to have fun)
Carlos
Carlos
Are you live in Palestine? Are you Palestinian?I was slepping under the bed to avoid bombers raid at nigth!
Try to spend nights in your bed disturbing her.I was slepping under the bed... ... beauty spanish wife disturbing me a lot...
The main problem is 90% of people can't hear a difference.
Of the 10% that can, 90% of those can't tell you which is more musical.
I'm talking about people that own $10,000 worth of stereo equipment, two channel, no video here.
In a controlled demonstration people pick the one that sounds the most like a boom-box or a factory car stereo (pair of 4 X 10 variety).
This is on modified gear that is so musical it makes you want to weep.
"Ohh, I picked the wrong one"
They may not be able to 'hear', and you didn't 'say' anything about their choice, but their ability to pick up small body language cues seems to be OK.
March them next door to the music store and play them a Yamaha studio model piano, a real one, no electrics here please.
Go back to the store and dig out a solo piano on DMP label.
No problems now.
The Leach has incredible bass, but no MUD.
If you like MUD, I can tell you how to get it from your Leach.
The Leach has incredible highs, but it is so clean it can sound SOFT.
If you like an etched, glassy sound to your highs, I can tell you how to get it from your Leach.
If you like musical, just follow the plans at the Leach site.
Nothing is perfect, the Leach is a work in progress for almost 30 years now.
Too compliciated?
Build a GAS Grandson, or an original Leach with an EF2 output stage instead of the current EF3 (tripple) outputs. The SAE XXXI is about the same with Darlington outputs (EF2 in one case).
No problems now.
Too compliciated?
"Never built either but I bet the P3A is a lot easier to get working ..."
Why would you think that?
As I described above, the original Leach, less the pre-drivers (not needed today because of higher gain parts), has only TWO $0.10 plastic transistors more than what are in the P3A. Same number of caps. Same number of resistors.
An EF output stage is usually easier to get working OK, a CFP can be tricky.
Ever try to find where that 2Mhz is coming from when you don't have a 'scope?
I find execution and attention to detail count as much as topology does.
If saving the time and money on those extra TWO transistors will allow you to do a better job on a P3A, then go for it.
DRC said:Never built either but I bet the P3A is a lot easier to get working ...
dave
FWIW, 4 channel Leach 4.2 (my first DIY amp) just fired right up, with only one glitch caused by my rushing to get it done. I reversed the power supply leads on the last channel, which was saved by using the 100R resisitors Dr. Leach recommends. I built it pretty much as described in hte article, kept the leads to the output transistors under 3" or so and no problems. I simply dialed in the bias (I used 125 mA) and plopped it in my system.
As for the sound - I am very happy with it. I use a pair of channels bridged to drive my subwoofer, a JBL 2245H in a cabinet tuned to 24 Hz. Plenty deep and powerful enough for music or movies. I am not sure if it makes a difference, but I used the single NP option for the feedback capacitor. Nothing fancy, a panasonic (I think) from Digikey.
The other pair of channels drives the tweeters on my first active crossover speaker. Still dialing in the crossover, but I am happy with the Leach in this application, too.
YMMV, and I have not built a P3A. On a passive XO speaker, I liked my A75 a little better than the Leach, but not enough to put up with the heat in the summer. The A75 seems a little smoother on top, but of course that may have been due to having gone to all the trouble to build it and get it running.
I am not Palestinian, but i look alike
And this can be dangerous those days.
I disturbed her other bed side too...but she is only beautifull, a little cold too.... once a week i can make her stop talk for some time. Damn Spanish beauty, really pretty that damn woman!
All you are completely rigth, specially the USA people (of course)
Related to future, we have pure water.... will be valuable as Oil in near future...My god!... uncle Sam will come here to protect Democracy!... this is awfull because we like them.... but, send cowboy back to farm, please!
Carlos
Carlos
May i ask you some?
You said P3A is simpler than leach.
But you put some points.... i use this way.....because army..... receiving cw instructions....... this way.... for me this is normal.....but i know you do not do that normally, those points are something to be concluded by ourself.
But can conclude a lot of things.
Simple.... is better
Simple.... is worst
And a lot of ideas can come, can you please tell us if this points had some meaning, or not had a meaning.
If had a meaning, please tell me if i am rigth, we have to conclude, that's what you want?
Since the beggining, electronics teacher told us that each amplifier stage create their own problems, their distortions.
The best amplifier is a wire with gain, not discovered yet.
This way, i can conclude, simple is better....but, if you read all forum, twice times as i read, you will see that people is putting a lot of stages, and feedbacks, and stabilizer, and mirrors, and long tails (why not normal tails, short tails, looooooog tails seems something falic.... the man with looooog arrow.....looooog car....loooog tail, theres a psychological problem related the first that use this name....this one may have short......
And i cannot understand where first teachers fail, never heard them saying, make a lot of stages, to compensate errors one of the other... this way the second corrects the third, and the fourth will correct errors from the third... and mirror to balance, because is unbalanced, supply is unbalanced, or is balanced, have to unbalance before balance...and this goes to enormous circuits... and when i assemble them.... strange sound, have a juice artificial, a damn international tang brand and a orange juice and compare them!.... if one stage is correcting the next, what will happens with the last one....oh!, it will return to input.
Have 10 old friends, all them audioholic, audiomaniac, audiocrazy, audio amateurs, the name you want..... was a damn shame when i read entire story of Mr. leach, their technical ideas in seventies, and the circuit itself....but when people start to hear... all them perceive lack of bass and say... baaaaad!....i perceive some time passed, why?... because i done the whole thing, had to think is good, if not, who i am?
Those friends like americans as i like, and they spect better sound related our referenced units (one Marantz, one Macintosh and one Death of Zen)... they never joke with that, is our club, and their we do not joke when sound judgements are done.
I will be happy if you can say clearly what you intended to say...if you intended to say something, because i also use dots........
regards,
Carlos
Simple.... is worst
regards,
Carlos
I visited Metaxas five year ago.
Could not have some schematics, but i was very interested related to their work.
I will receive AKSA, i think i will be very happy to here ist sound.
Also i will know top secrets!
My friends, 10 friends, audioholics are making pressure to see schematics...i am saying no!...because Hugh do not want it.
- But hugh will never know you show us!
- But my concience will know very well.
The are studdyng hard (damn boys those friends!) the hugh pictures of AKSA 55 and the stereo unit.... the think the board is alike a sandwich, two small bords one over other, and some SMD or small capacitor plates mounted there in secret... they asking me to inspect boards and make Ray X..... i will not let them see different than normal screwed position, assembled...not to inspect solder sides of measure continuity.... have to respect agreement made.
My friends are nervous with me. and they think they discover something... take a look.
Not to get away, to much of thread subject, but i think this can be interesting thing to analise... my friends are enginneers and all kind of professions, 80 percent them have universitary degree..not stupid people and audio maniacs!
Carlos
Carlos
Regarding the "lack of bass" in the Leach amp: the electrolytic capacitor C6 in the feedback network is intended to be two series capacitors or one non-polar electrolytic. If you use a single non-polar, you must jumper the space for the second capacitor. Otherwise, no bass.
I did bet that the P3A is easier to get working
Carlos,
I am sure both of these designs, built to the designers’ specification and on the designers PCBs, work real well. My practical comment (OK, maybe slightly off-topic) was purely based on the complexity of the actual circuits (as published) and the likelihood of bad components / dry solder joints etc that can prevent a circuit from working correctly. I did not mean to imply that the P3A was simpler to design, or worked any better or worse than the Leach, just because it had fewer components.
However, it seems to me that the designers of these amplifiers seem to have approached the same basic design (PP class AB) from two different perspectives. As I see it, in the Leach the forward path has been engineered for the minimum error with a compound feedback arrangement to keep those extra bits in check at HF. In the P3A the forward path is less accurate but the reduced group delay allows more (and simpler) global feedback to correct the errors. Only a double blind listening test should decide if the extra complexity of the Leach is worthwhile, but I seriously doubt that I would hear any difference.
PS
I made my second post in response to a post saying that the only difference in component count (between P3A and Leach, although an earlier variant) was 2 small signal transistors. This didn't really tally with my memory so I went back to check and I reposted with links to what I consider as the reference designs and restated my first post (complete with ellipses ).
dave (ellipses – too many years programming C)
Carlos,
PS
Yes, all them good! no such a difference
But something different of wave form and distortions exists... i cannot say what is!...have no theorical conditions to discuss.... this way i feel like an human can feel.... the voices of a coral music.... the precision off a cello.... the thunder of drums and delicacy of little bells, cymbals.... the warm of flute, the magnificence of the harmonica... we can hear them in real world, and we can hear them recorded... this way, one can do better some instruments, other can do better reproduction of others... as an audio maniac, audioholic, i like to think about comparisons.... but all them is compared in high skies...high level quality both of them.... one simple, other, state of art design from seventies....incredible how they can be compared sometimes.... as a bicicle asking to surpasse an Ferrari in road.... we have some joke about that.
On Volkswagen damage was attached into a ferrari... and they go. both drivers combined that when Volkswagen sound its buzzer noise signal is to ferrari reduce speed.
And they passed in front of a Police, he took the radio and inform. A ferrari and a buggy..... 150 miles an hour.... from eat to west, road number zst mile 241 point.... and believe me or not.... the buggy is asking to pass the ferrari!!!
Carlos
Carlos
Try the index page and then click on"
"Build a Low TIM Amplifier - Parts 1 and 2 - Articles I wrote for the Feb. '76 and '77 issues of Audio magazine that many people have asked me to post. Several following versions are included. The Leach Amp plans linked above are for the latest version of this amplifier. This is a PDF document which might take several minutes to download. I recommend right clicking on the link and saving it to your hard disk. The amp pictured in Fig. 1 has been running over 8 hours a day, 5 days a week, in my office since the article was published. "
Delete predrivers.
Delete predrivers.
I have build both amps using my own PCB layouts, and with minor modifications to both amps.
My main modifications are:
Leach:
Changed the number of output transistors to 10 (5 sets)
Changed the protection to match 5 sets of transistors.
Changed the LF cut off cap in feedback to 470uF not polarized giving plenty of bass.
Decoupling rail voltage, by using 1uF on each collector of the output transistors.
Resistor between emitters on driver transistors is bypassed by 1uF.
Bigger Emitter resistors on input (330ohm) to decrease open loop gain
I used other transistors because I could not get the original and prefer flat pack types.
Input: BC546/556
Bias and protection: BC546/556
VAS: MJE340/350
Driver: MJE15032/15033
Output: MJL2381A/1302A
P3A:
Current source for input replaced by transistor/transistor type ala Leach, same current.
I think the leach amp is more work, but it’s worth it. But the P3A is a very nice amp, the only problem is that it runs into voltage limitations when comparing to the Leach amp.
For a first project I will definitely favour the P3A as this has much fewer parts, and therefore less risk of error when assembling.
\Jens
Leach:
Input: BC546/556
VAS: MJE340/350
P3A:
\Jens
- P3A Vs Leach
