I have a pair of P.Audio 4528 horns for 2" comp drivers. These are not cheap plastic horns, they are heavy duty ABS + fiberglass horns. USSpeakers has info on them here:
P.Audio PH4528 Horns - P.Audio PH-4528 - PH-4528 is a 2" horn with a 60 x 40 dispersion.
Specifications
Throat Size
2" / 50mm
Dispersion
60°x 40°
Cutoff Frequency 400Hz
Mounting Type 4 Bolt-on
Construction ABS + Glass Fiber
Net Weight 3.63 lb. / 1.65 kg.
Mounting Information
Overall Width 17.72" / 450mm
Overall Height 9.8" / 249mm
Overall Depth 9.09" / 231mm
These sell for $105/each. Asking $100/pr + shipping. Paypal accepted.
Specifications
Throat Size
2" / 50mm
Dispersion
60°x 40°
