Re: deep thoughts
...correct...
No...Sawzall said:
.........your first name is not Jack?
No...Sawzall said:
I would expect that having additional gain would enhance the slew rate of a amp.
You are.....Sawzall said:
But I could easily be wrong.
Sawzall said:
...is gain neutral as to speed - meaning that it just tells us an amplification factor and has nothing to do with speed, rate of change, or velocity of sorts (however you choose to express it)?
...correct...
then explain why...
If additional gain, in and of itself, does not enhance slew rate....
And gain has no relationship with rate of change...
AND slew rate is a measure of speed of change (or the ability of an amp to change voltage specifically, as noted by its units of measure V/sec).
How would having gain in the output stage enhance slew rate - in an amp that was not starved for gain in earlier gain stages, or having an output stage unable to follow the earler stages.?
Re: then explain why...
http://diyaudio.com/forums/showthread.php?postid=168561#post168561
Sawzall said:If additional gain, in and of itself, does not enhance slew rate....
Sawzall, suppose you have a fast output stage, faster than the driver.
If the driver has 25 V/us which slew rate would the output of the output stage have if the gain was 4?
Correct, 100 v/us.
That's what the whole thread is all about but Mike is proving something else which I don't know what it is.
Now, is an amplifying output stage good? That's an another story.
Correct, 100 v/us.
Thanks peranders...peranders said:Sawzall, suppose you have a fast output stage, faster than the driver.
Correct, 100 v/us.
I am not sure i understand...but i think you are referring to the fact that two-pole compensation got mixed up in this along the way?
http://diyaudio.com/forums/showthread.php?postid=168411#post168411
No, you don't, ..... That's the problem.mikek said:I am not sure i understand...
Ok, Mike we know that now. But I and many with me don't agree. Just as simple as that.Most designs of this type run the output stage in common emitter mode....this is essentially a bad idea,
...and...what is it exactly that you don't agree with....?
Hi Mike
I think the main reason that output stages with gain are not everyone's favourite is because they are sometimes a PITA to get stable.
A second reason may be the fact that the humble emitter follower is one of the most linear applications of a transistor one could imagine, even though some output stages with gain would allow additional local feedback.
Just one thing to remember:
It is very seldom THE piece of equipment that excels in exactly one discipline that becomes a classic !!! So achieving high slew-rate ALONE is worth nothing !
I am however always open for new things and so I did once perform simulations with a circuit that has an output stage with gain.
Simulations looked very promising but I wasn't able to try it out in real hardware so far.
Even though the theory behind technical stuff is most often the interesting part for an engineer, it is the real-world behaviour that counts in the end.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=7058
Charles
Charles
Endless loops do me no good.
Mikek, the endless loops of referring back to a post that does not explain does not help me - in the next five posts forward from your link basically just points me off to a bunch of URL's. Lots of heat, no enlightenment there.
Thank you for your reply Peranders.
MikeK, to look at it another way, if you had the driver stage that had the 100 v/us, and the output stage was our humble emitter follower with its less than 1 gain. Would the amp not still have roughly the same slew rate without the stabilty issues that outputs with gain can have?
Correct, 100 v/us.
phase_accurate said:Hi Mike
Charles
hi Charles,
thanks for well considered points. I think you'll find we are in agreement on one point at least....i don't think CE output stages are very stable either...which is why i suggested generating the gain slightly before the output stage-proper.....here:
Not sure about this. When you say linear what do you mean, specifically?A second reason may be the fact that the humble emitter follower is one of the most linear applications of a transistor one could imagine
I mean linear in terms of input to output voltage transfer (beeing unity with large accuracy). If this wasn't the case all those amps with emitter follower output stages, that take feedback before the output, would have quite high THD.
Charles
Re: Endless loops do me no good.
What is the hardest thing to design: A fast driver or a amplifying output stage?
I'm in again. Couldn't help it.
Yes, accordning to me.Sawzall said:MikeK, to look at it another way, if you had the driver stage that had the 100 v/us, and the output stage was our humble emitter follower with its less than 1 gain. Would the amp not still have roughly the same slew rate without the stabilty issues that outputs with gain can have?
Charles
An emitter follower is a gain stage with 100% local feedback. Feedback, as is known, makes a stages more linear. Naturally the EF stage is very linear.
Collorary: An EF output amp with zero feedback is an oxymoron.
Jan Didden
(Not sure about the meaning of oxymoron, but I like that word).
Lots of things have a "voltage transfer" close to unity into a loudspeaker load. Like a coil of wire or a relay or a forward-biased diode. Would you want to listen to your favourite musice through a forward biased diode?
I feel compelled to douse the slew rate debacle. For most loudness of music with typically efficient speakers, not much more than 5V/us is needed. We are debating a red herring.
- Output stages with gain Enhance Slew rate
