Hi.
Pulled out some old school switches from an amp. Stamped on some of the switches is "3A - 125/AC" and under this is "JAPAN". Can this type of switch be used as a on/off switch between the wall outlet (120V) and transformer of my GC PSU?
I'm using a 2A slow-blow fuse. So I am assuming the fuse will burn before the switch burns, or anything else burns, if something happens to go wrong.
Any input would be most appreciated.
Thanks.
Thanks.
mcelaj said:Hi.
Thanks.
that means the switch allows 3amp going through it. at 110v (here in the US), it means 330w at the transformer. at 50% efficiency (for a class b amp), that's good for 150w output. each gainclone is good for about 50w, so your switch can handle at least 3 gainclone at full power at the same time.
That's a lot of sound.
