OTL for 40-80ohm speakers
I have a fresh plan making a little different otl, for driving speakers having multiple 8ohm series connected speakers.
At first, it sounds like quite easy load for otl.
Ok, first of all I want 50watts/channel for 80 ohm impedance.
There should be option for half impedance, like 40 ohms.
4 x EL509 / channel should do this job easily?
powersupply/power transformer will be 2 x 110VAC. 400VA/ch, should be enough..
what do you think about this idea? :)
50w is quite a lot for an OTL !
Just do some math:
A EL509 as cathode follower has an R-out of 1/(0.018ma/V) = 55Ohms. As circlotron it's a bit lower and as futterman its half the cathode follower R-out. So even without further global feedback this isn't bad.
Power:
P=(I^2)*R, for P=50W and R=80Ohms, this yields: ~0.8A-rms and ~1.1A-peak and for 40Ohms: ~1.1A-rms and ~1.6A-peak.
EL509 max. Ik is 500mA. So you can calc. for yourself how much tubes you need for that much power you want.
I have never built an OTL amp, so I can't tell you about some good designs. But I have some names in my head. Just google for: "Rosenblit OTL", "Sandman OTL", "Pickie Makovski OTL", "Murray OTL"
I just looked into Bruce Rosenblit's book and on page 74 he says: "The maximum current that a 509 can pass is just over one amp."
This disagrees with the datasheet value of 500mA and seems to be the solution why bruce gets 80W into 8Ohms with "only" 8 tubes.
According to this, 4 tubes per channel should be enough. But as I said, have neither used EL509 for audio nor built an OTL
