Really like the B-1, but with some speakers a little gain is needed in my setup.
I have seen some older posts ( '05 ) that suggested the P 1.7 or something similar. Anything better since then? Circuit board availability would be a plus! I'm building the Pearl 2, so only line stage is needed.
Russellc
Russellc
Check out the JFET BOZ thread here... doesn't get simpler than that. Apart from that there's the preamps on the passdiy site... BOZ and BOSOZ.
I have the board for BOZ already. I'll put that sucker together, I've had those boards since the 90's! (Have the Zen board as well.)
russellc
Russellc
Don't forget the UGS by CheefDeGaar That's what I will test next.
We recently designed a motherboard for the UGS preamp with user PierreQuiRoule, with the following features :
- Support of any UGS versions modules ( fixation holes and connector pins are true "UGS standard")
Integrates circuitry for 6 inputs; 2 balanced 4 unbalanced, has 2 sets of direct parallel outputs, balanced ( bi amp in mind )
Versatile use of relay coils DC is possible : 5,12, 24 V ...
Only a single Lorlin (external) 2C6POS is needed for relays switching and led signalisation (additional source of DC for the circuitry is also needed)
Automatic switch to GND of the minus inputs of the UGS when using unbalanced sources, no headache ( easy unbal to bal converter )
Balanced ladder connections are implemented ( 50k, volume before the UGS )
Double mono PSU is what we had in mind. However, it is also usable with a single audio power supply ( +/-24V ).
We also re-arranged a little the UGS_V3 layout. Boards about same dims, slightly greater size pads for soldering.
I can't really tell more for now. It's top-secret !
Best,
nAr
- Other DIY Pass pre amps
