Perry Babin said:Measure the DC voltage on each side of C42 and C49 (near the RCA jacks). Use the secondary center tap for the reference (black lead).
C42
Round pad:
Square pad:
C49
Round pad:
Square pad:
Both round pads were 13.1 volts
and the square pads started out at 1.7 and slowly raised to 3.2 volts within a couple of minutes I had it on.
Perry Babin said:2N5639?
I think those are the ones I replaced because they popped awhile back. I will pull them and check voltage.
Perry Babin said:There are two resistors. One end is connected to the capacitors you measured voltage on (they are next to the ceramic disc capacitors marked 101j). The other end probably goes to the muting transistor. Pull one of them in one channel to see if the DC goes away.
Nope - Still voltage
- General Interest
- Car Audio
- Orion HCCA 275G4
