Hey everybody. Brief history, originally I was just going to make a dipole woofer, but I ended up with some more drivers so I figure I'd just combine it all to make an big orion clone.
What I'm wondering is about the mid-tweet vertical position. I have the PMT1 drivers, so basically I'm just stacking the PMT1 on top of the dipole woofer and putting on some side like the Orion. Is there an optimal position for the Mid-Tweet combo? Right now I have it modeled so that the center between the mid and tweet is at my ear level when sitting on my couch (~41")
So yeah, that's it. Just wondering how high to put the mid-tweet panel (which is just a PMT1).
Attached are some pictures of my model. I'd like to come up with some more creative sides to hold it together, but I'm drawing a blank right now...
In case you missed it:
ORION owners have access to helpful information and updates. The design is stable and has proven itself over a number of years now, but I still keep my eyes, ears and mind open for worthwhile revisions.
These are the specifications:
Open baffle cabinet
Outside dimensions: Height 46.25" - Width 13"
Depth 2" at top, 12" at base, 16" at 14" up
Weight 60 lb (27 kg)
3-way active speaker system
Crossovers at 120 Hz and 1440 Hz, both LR4 (24 dB/oct)
Crossover/Equalizer using two ORION ASP printed circuit boards
Tweeter - Seas T25CF002 - No, not a ribbon -
42" up , no 2.8 kHz notch filter as in PHOENIX
Preferably no grill to cover the tweeter
Midrange - Seas W22EX001 - No, not a smaller diameter -
Front mounted to baffle, no spine, but see Revision 0.1
34.5" up, 5 kHz notch filter
Woofer - two Peerless 10" XLS, 830452
Push-pull mounted in H-frame of 11.5" x 11.5" x 24.5" OD
Each driver with its own >60 W amplifier
etc.
Those are the center line heights of the drivers.
The gap between your main panel and woofer section would be highly undesirable.
AJ
Open baffle cabinet
etc.
AJ
lol... yeah, I actually totally missed that ... DOH! I get lost on his website there's so much info 🙂AJinFLA said:In case you missed it
aw... bummer. I just came up with some new sides I like (it's a slow day at work), but it keeps the gap there. What happens thats so bad when the gap is there? I'm just trying to understand as many issues as I can when building a speaker like the Orion. Would it be better to build the PMT1 and woofer as two separate entities? I sort of like the idea of just having 2 big speakers, rather than 4 smaller ones.AJinFLA said:The gap between your main panel and woofer section would be highly undesirable.
How about building the entire speaker taller, like a tower, by adding a base below the woofer module? The mid/high module would then be at your desired height, without changing the critical Orion dimensions. Someone correct me if Linkwitz advises against this.
Or, consider adding another midrange to the "gap" you have in your current design, making an MTM, as in Linkwitz' Phoenix. In this arrangement the tweeter would be at ear level, but the mid frequencies would appear to be there also.
This of course makes for more complex and expensive design and possibly require crossover mods, but others have built Orions this way with favorable results. There is (or was?) a link somewhere on SL's site to just such a design, called the "Bob" loudspeaker - I think he used different woofers, but the mids & tweet are the same as best I can remember, just in an MTM arrangement.
Sorry to resurrect this, but I'm trying to figure this out
can someone explain this to me? I just emailed Linkwitz for some advice on whether to stack the PMT1 on top of the woofers or make an Orion type "enclosure", and he said that stack the PMT1 on top of the H-frame is fine, and that a small stand underneath the PMT1 to bring it up a little higher would give breathing space around the PMT1.
I'm very new to speaker building, so I don't understand what's going on. Could someone help explain what downsides there are to having a "gap" between the main panel and the woofer section (or send me a link that I can read up)?
thanks a bunch 😀
thanks a bunch 😀
I don't think the gap would be a problem. Indeed, the PMT1 is very similar in dimensions to the main panel of your rendering.
I think what AJ was concerned about was front/back cancellation since that distance is rather smaller on the lower edge of your panel than it is to the sides.
Aesthetically, I would like the look of your speaker with the gap filled in, but that's just me. 🙂
Acoustically, I don't think you'll pay much of a penalty for doing that. The horizontal polar response is the most critical, and your design seems very close to the basic Orion shape which is good.
Davey.
Davey.
If Linkwitz says it's OK it is. You can have the gap, or fill it in just using a taller panel - personally I think that would look better.
Thanks a bunch for your replies guys 😀
The more I think about it, the more I'm leaning towards just completely copying the Orion shape (i.e. filling in the gap). Still a little resistant since it would be nice to have a unique design, but the Orion does look nice.
Again, thanks! I should start cutting wood the weekend after next (assuming nothing comes up, but some how something always comes up 🙁 ), so I'll keep you all posted!
Please keep us up to date on the progress of your project - I'm sure lots of us would like to see photos, etc.
Hi Santiu,
my main concern would be the reduced SPL capacity/increased distortion from the smaller panel. There's nothing wrong with the PMT1 as is. It's just that having the larger panel gives you a bit more SPL capability by increasing "D" http://www.linkwitzlab.com/spl_max1.xls.
That allows you to cross lower, perhaps at the 120hz like the Orion, without running the 8" Vifa too hard.
If the gap is your hearts desire, by all means do so. Who am I to contradict SL, the man who came up with all this himself🙂 .
AJ
- now back to lunch😀
AJ
AJ, thanks for that clarification 🙂 It looks like I'm gonna go Orion style with no gap.
For reference, attached is just the a model of my Orion clone idea (now it really looks almost exactly like the orion) that I cooked up over the long weekend. All the black stuff will be made from 3/4" MDF. The main panel and sides will be made from solid mahogany 3/4" boards.
I've got another couple detail question for your guys. Would it be of any benefit to isolate the main panel from the "frame" with some sort of rubber gasket? Since I think I'll be making the main panel from solid boards, and the boards only come up to 12" wide, that also lends itself to putting a tiny split (which i can also fill with some lossy material like a rubber gasket) in between the midrange and tweeter and isolate those from each other since that main panel will have to be made of al least two boards anyways. The woofer will be held Phoenix style by the magnet, so I'm not sure what effect, if any, isolation like this would have. Just wondering...
I'm also thinking of putting a radius or bevel on the front outer edges of the side panels (not shown in attachment). Might this result in any adverse effects?
It wouldn't hurt to isolate the panel IMHO. Necessary? Probably not. As far as the midbass goes however, why not use a bracket like SL recommends with the Orion?
If you get the one like I use (L-shaped T-section @ Lowes), its a nice way to hide the wires also. IMHO😉 .
AJ
AJ
- Orion Clone driver height question
