What's the resistance between pins 9 and 10?
P Perry Babin Member Joined 2003 bcae1.com 2010-12-13 10:01 pm #41 2010-12-13 10:01 pm #41 What's the resistance between pins 9 and 10? ••• More options Share M mike49504 Member Joined 2006 2010-12-13 10:03 pm #42 2010-12-13 10:03 pm #42 363.1 ohms ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2010-12-13 10:06 pm #43 2010-12-13 10:06 pm #43 Is it possible that you reinstalled the original IC? ••• More options Share M mike49504 Member Joined 2006 2010-12-13 10:07 pm #44 2010-12-13 10:07 pm #44 No i put a new one in i threw the old one away before i got the new one out. Should i try another new one? ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2010-12-13 10:24 pm #45 2010-12-13 10:24 pm #45 No. It's unlikely that you'd have a defective one that has precisely the same fault. If the power supply FETs are still out of the amp, pull the PNP driver transistors. Does that allow the IC to produce the proper output waveform? ••• More options Share M mike49504 Member Joined 2006 2010-12-13 11:04 pm #46 2010-12-13 11:04 pm #46 I removed the 1023's from the driver board and the signal looks better . When thhe driver board is out of the amp between pins 9 and 10 i get 0.441K ohms with it in the amp i get 362.3 ohms. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2010-12-13 11:23 pm #47 2010-12-13 11:23 pm #47 Does it look perfect? Check the diodes that were connected in parallel with the base and emitter of the drivers. Check them for leakage. Also check the drivers. ••• More options Share M mike49504 Member Joined 2006 2010-12-13 11:26 pm #48 2010-12-13 11:26 pm #48 Without the driver transistors in the wave form looks perfect I will check the diodes ••• More options Share M mike49504 Member Joined 2006 2010-12-13 11:38 pm #49 2010-12-13 11:38 pm #49 Checked the diodes all seem fine no leakage ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2010-12-14 9:59 am #50 2010-12-14 9:59 am #50 Confirm that the collector pads for both PNP drivers read 0 ohms to ground. ••• More options Share Prev 1 2 3 First Prev 3 of 3 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio Orion 1200 D Top Bottom
