I will get some pics of the speakers when I get off work. While the paint work was fantastic, the fit was terrible. I told the guy not to mess with the edges of the inserts because I had them fitting perfectly. Turns out someone else did the work and the guy I talked to didn't fill him in. I got the inserts several days after everything that was painted black and then took a couple of weeks to get some time off to do the assembly. It wasn't till then that I found out that nothing fit right. I went back to the place to see what could be done and they were out of business......lesson learned I guess. I should have checked through every step of the paint process.
- Full Range
- open baffle project
