I've found having it reflected unimpeded to be best in my room, they are aligned straight on with the front wall which is plaster on stoneThe magic of dipoles is in having that rear radiation, and it (all directions actually) should have same spectral balance to sound really good. Wall abrorption is also frequency dependent, this makes thing even more difficult.
I've been able to compare the two quite simply, the Jordans are in the VTL cabinet but the back is removable, I prefer them as dipolesHighly directive speakers dominate with direct sound and I don't like that. Many others do.
One important thing is that the listener must be at least 60cm, preferably more than 1 meter from back-wall! I would like to say that this is the most obvious fault at least here in Europe and Asia, based on photographs!
I totally agree with that.Without back wall the listening gets more relaxed from subjective point of view.
O.K. Scott, I need your help in stopping this wall nomenclature insanity! The title of your thread says 'front wall' yet others have referred to it as the back wall. From the speaker's point of view it's the back wall since it's behind them. However from the listener's point of view it's the front wall since it's in front of them. It's my room and my wall so I contend it should be called the front wall! I sound like my dad.
Oh, it's the other wall? Anyway I feel inclined to point out at this point that a dipole can be a narrow band phenomena and that an open baffle isn't automatically a dipole. That said, I still feel that whatever reflections you create, and how, are the end result of interest.
I think it's fair to say that an open baffle isn't automatically a dipole and doesn't give that figure of 8 radiation pattern as Charlie has measured and others have observed. And the bass doesn't cancel as much as the calculations would have you believe. Then place it in a room at the requisite minimum distance, perhaps maximum distance no more than about 6 feet(?) from the wall in front of you and enjoy those reflections......
whatever sounds best in the room. Ive had around 20 or so open baffle designs both planer magnetic and cone type. Seems they ALL were best at between 4 and 5 feet from wall. They all sounded less convincing at less than 4 feet( mid range color and spatial issues) and at more than 5 feet didnt seem to gain anything.Never went more than about 6 feet so cannot say BUT there may be advantage in bass at large distances.
I see two issues.1- The bass cancellation due to wall distance
2- mid range coloration and less depth if too close to wall
The bass cancellation thing tends to happen around 120 hz give or take and with some playing around with position you find the best compromise. Sometimes I hear people say that dipoles dont sound dynamic. I suspect some of this is the suckout around 120hz that gives that impression
Where can I learn more about this ~120hz suck-out with dipole speakers? Can you please post links to any papers, forum discussions? Thanks.
This might help Boundary effects
The "thing" with dipole bass is that it's rear wave is in opposite polarity. Near the wall it will be opposite polarity even reflected, so summed will attenuate. Monopole will accentuate in low end. Until the phase turns over.
Calculators like SBIR work only with monopoles.
sorry zmyrna I dont know of any links or papers. Years ago I was well into development of a planer bass panel and was hearing HUGE differences in bass dynamics with different positioning. Some say that dipole is easy to position for bass region due to less room interaction. Well there is some truth to that BUT the issue I was hearing I think had to do with the subjective effects of a dip in FR around 80-120 hz. This is an area I believe has a lot to do with how puncy and dynamic percussion sound can be.
Anyway I found out that at different distance from wall will change this suckout. it has to do with the wave bouncing off back wall and cancelling the positive wave coming from speaker.
Even a monopole has some of this issue I believe but it is perhaps hidden better in the sea of room effect issues??
May as well put them in a horrid boxIf that is not an option, you can wrap the back side with foam or towels.
I decided to not have dipole low bass, when I was tinkering about AINOs. My idol Gradient 1.3 has monopole downfire bass, and also the just released Gradient 1.4
Monopole bass is actually omnispheric in dispersion and it is not so critical to positiong, at frequencies below 100Hz and is also more efficent even as a closed box. When we cross a omni/mono to a dipole or cardioid, the transition range is cardioid. Front wall first reflection is in most real in-room cases somewhere between 100-400Hz, just like the floor reflection null. If these happen at same frequence, we get really severe suck-out. At worst scenario also sidewall first null happens there too!
Important thing to remember is that it is impossible to eq first reflection nulls by setting a peak correction to signal! If we try that, also the amplitude of reflection goes up and the sum is still zero! This applies also to front-wall cancellation of dipole low bass, it is impossible to eq!
It's interesting to concentrate on the reflections of open baffle bass. The requirements appear to be slightly different than further up the spectrum. They need to be a certain distance from the front wall in order to have any reasonable bass, but too far away and the cancellation caused by reflection can be below the crossover point. Floor reflection shouldn't be a problem for bass and also if they are placed close to or against the side walls this reflection too is no problem
Pass Open Baffle: need helpI've been trying to find details of that particular SLOB, can you help me out?
- Open baffle maximum distance from front wall
