860 is direct replacement for 660....
Boky
Is it the difference are that the OPA660 have an open loop output buffer and the OPA860 have a close loop output buffer ?
Btw, would I get a better result than using a THS4031 as a I/V amp ?
Thank
Bye
Gaetan
Boky
Agreed. Better linearity also, apparently.
jd
Hello janneman
I've use wayback machine at the web.archive.org and I found the new link for the dc servo file ;
http://web.archive.org/web/20041027034615/home20.inet.tele.dk/kou/dcservo.html
You can directly download the file there;
http://web.archive.org/web/20041027034615/http://home20.inet.tele.dk/kou/files/servoamp.zip
Btw, would you know if I can use the OPA860 as a drop-in replacement to goes into the circuit in the post 46 ?
Bye
Gaetan
Thanks!
If 4031 in right schematic and PCB tracing - no, if in standart - yesBtw, would I get a better result than using a THS4031 as a I/V amp ?
Hello
Here is the THS4031 I/V amp and also the OPA860 I/V amp (replacing the OPA660 by the OPA860 if I use this one) schematics I would use;
Any comments or suggestions ?
Thank
Bye
Gaetan
Hello
Thank
Bye
Gaetan
If I would use the 860, I would not fiddle with the input offset compensation. I would run a servo into the base pin 3. Clean, stable, no need for adjustments that will drift.
Anyway, these two circuits are completely different concepts and cannot easily be compared. The 860 is best for the DAC and I would prefer that, but not having tried out either it is just my preference.
jd
Hi Nazar,
I have checked your web-site.... nice analog power supply regulation for that DAC... and nice I to V for that Analog Device DAC... any info in English?
Boky
transformation current / voltage is happening here at the resistor (the resistance 50om is too much, DAC will produce distortion, moustly the quadratic through lack of compensation in the initial displacement -2mA 1541) Operation amplifier serves only noninverting amplifier with Ku2.Here is the THS4031 I/V amp and also the OPA860 I/V amp (replacing the OPA660 by the OPA860 if I use this one) schematics I would use;
OPA660 here included in the usual way without negative feedback, sound not bad, but for my ears a bit too much distortion and "colored"
Hi Boky,Hi Nazar,
Boky
its not only power supply regulation, the analog part of the device (1794DAC) is organized on the principle of "double Mono", electrolytic capacitors are not used, instead are used negative feedback free electronic substitutes, with has a stable impedance ~0.2Om in the band to several tens of megahertz shunting NP0 0,1 microfarads Murata GRM31 in close to chips. This structure provides in a comparison with the best series audio electrolytic capacitors significantly better results as well as the simplicity, accessibility and small price.
That I/U stage based on 860(and 844+5534) have negative feedback only in audio band, therefore has only advantages of NF
I dont have English translation yet, only in Russian at the moment, if necessary i can do, i read in English very well (especially technical text), but the writing and speaking difficult to me, no practice. I Designing DAC/ADC in a long time, if you have any questions about that devices (DACs 1541, 1794, I/U, electronic training of electrolitic capacitors, amplifiers and others) i will answer, but here it is OFF, in another(new) topic on this forum
Best regards, Nazar
it will not work, current output of the most parallel(multibit) DAC should be under the potential of zero volts. For this potential on DACs current output the pin 3 opa860 should also be zero volts (it puts potential of pin2)If I would use the 860, I would not fiddle with the input offset compensation. I would run a servo into the base pin 3. Clean, stable, no need for adjustments that will drift.
transformation current / voltage is happening here at the resistor (the resistance 50om is too much, DAC will produce distortion, mostly the quadratic through lack of compensation in the initial displacement -2mA 1541) Operation amplifier serves only noninverting amplifier with Ku2.
Best regards, Nazar
Hello Nazar
Ok, I could reduce I/V resistor to 30 ohm.
Thank
Bye
Gaetan
I stand corrected, you are right. But I would still like to use a servo, only at another point. haven't looked at it yet, but should be doable. I hate adjustments that need to be adjusted and can drift
jd
1541 with I/U resistance >15ohm give "coloration". opamp amplifier has gain only 2, with 30ohm resistor i/u you would have only 0.24v p-p (0db) on out with DC 0.06vOk, I could reduce I/V resistor to 30 ohm.
servo is simply another feedback loop, if the quality is above all that the servo should be used very carefully and attention. You have two options with the servoI stand corrected, you are right. But I would still like to use a servo, only at another point. haven't looked at it yet, but should be doable. I hate adjustments that need to be adjusted and can drift
1 shift by current on current input of i/u (860/861 power supply symmetry +-6v)
2 shift by voltage in the second stage after 860 (860/861 power supply asymmetry +9 -3v)
- Digital Source
- Opa660 I/V
