CarlosT said:Aren't the OPA549s not already high current?
The OPA549 puts out 8amps with a 10amp peak not as high as the lm3886.
CarlosT said:
How 'bout using a 551 at unity and then the 549s parallel but inverted? Hhhhmmm...
Rigth now, I only have the OPA552 (not unity stable). Anyway with the 551 in unity, all the gain would be on the OPA549. I match gain (13.75) levels of all my amps, the OPA549 would be passed the recommended gain max of 10
I’m really not sure how I will configure the amp, so I will use IC socket pin to make changes if necessary
