OPA549 x 8, bridge/parallel
I am planning on building this PCB I've designed. It will use 8 opa549, 4 in parallel for each channel. It can be used as a stereo amp, or, another pcb I am going to make will allow bridge operation through a DRV134.
If I am right, I should be able to run stable into 1 ohm when bridged, or 1/2 ohm when in stereo. What I want to do is have it easily power a 4-ohm woofer, and when I upgrade to a dual voice coil woofer (either dual 2 or dual 4 ohm, so a 2ohm or 1ohm load to the amp), it's gotta be able to handle it.
Would this power such a speaker? I care more about power with this project than sound quality, so would this circuit provide plenty of power into a 2 ohm speaker?
Second, does the PCB look good? It is a quick design and may need more work. The circuit is based on 8 LM3875 amp schematics, but with a resistor on each output to parallel them. The two resistors (input and the feedback resistor from - input to ground) are on the board, and the main feedback resistors will be mounted right on the chips.
Finally, how big of a heatsink do you think this thing will need? Would both heatsinks (4 chips per heatsink), from a logitech z-680 amplifier be enough, or will I need even bigger than that?
Thanks for all of your help on this project.
PRR
Joined 2003
What supply voltage and power goal are you thinking?
80V supply and 8A peak give, for one chip, 40V pk 8A pk or 5 ohms, 150W RMS. Actually less because the chip has voltage drop and because you can't safely run AT the voltage rating: utility voltage variation will kill chips. Also the 150W output is uncomfortably close to the chip 90W dissipation rating on an infinite heatsink.
+/-30V and 75W in 4 ohms looks possible. You may lose 20% power in the paralleling resistors, 60W per chip. Times four is 240W in 1 ohm, or times 4+4 in Bridge about 480W in 2 ohms.
At a glance: NO, because....
BIG.. MUCH bigger than this PCB. You can't put eight hot devices in a few inches: heat does not spread THAT well through even thick aluminum. (If you consider liquid-cooling....)
Hmmm... that does claim 505 Watts, but looks like a 200W job to me. Probably they use switching amps to hump the subwoofer; or let the transistors run awful hot and trust in thermal shutdown. Your chips will also shut-down, so that might work. Looks awful skimpy to my old eyes.
The max supply is +/-30VDC, so I was thinking of using a 40VCT torrid, probably somewere around 600-800VA.
How about these heatsinks?
http://apexjr.com/images/APEXJRTUNNELHEATSINK1.jpg
they are halfway down this page:
http://apexjr.com/new.htm
No, the amps from those speakers are not switching subwoofer amp. They are TDA chips, I can't remember which ones, but there are 7 of them, one for each satellite and two bridged for the sub.
