jaudio said:
Alcaid
on the datasheet(Open-loop gain and phase vs frequency)It looks like for a gain of 30 its flat up to 60k is that right?
Nope.
The y-scale on that diagram is dB gain, so a voltage gain of 30 = approx. 29.4 dB gain. If you see in the diagram the x-scale is logarithmic, which means it's flat up to about 27k or there about. (The log scale is weird in the diagram)
edit:
Used SplTrace to get a more accurate reading. Voltage gain of 30 gives approx 30k freq. With the recommended 1k-10k combo which gives a voltage gain of 11, the freq. is 100k.
Some here at the forum has said the graph is even worse in real life. (don't remember who)
jaudio said:Ok For a 26db gain frequency is flat to about 42k?
SplTrace tells me it's then flat to 50k. It's hard to read accurate this diagram without "cheating" with SplTrace.
26dB gain = 20 voltage gain
n00beR said:Lets us know how they look and sound once your trasnformer arrives
Keep up the good work Alcaid.
Well, the trafo arrived, and I've been listening to it for a couple of days.... SWEET! Love the sound of the amp+pre combo.
Onkyo amp for sale
Alcaid said:also the gain is too high for the OPA549.
You have a voltage gain of (22/1+1=) 23.
Try something like 11. (1k and 10k resistors.)
I've been reading this post, and want to build a 549 amp. I don't know why the gain matters though. Why can't I use a 22k resistor to not have a need for a preamp?
If I can't use the 22k resistor, I don't have a 10k resistor. I do have a 22k and a 1.8k or a 2.2k resistor. That would make either a gain of 13.2 or 11. Will that be the same as using a 10k and a 1k?
Banned
Joined 2002
Alcaid said:I've made a opa627 + buf634 pre, and I made it like this:
(The giant pot is a Noble, and the spacing around the BUF634 is because of the clip-on heatsink.)
Can i have this layout and Schematic please ?
If you use a higher gain the frequency response would roll off too early, and you would loose the top, and also people reports distortion in the midrange as a result.
I would use the 2k2 - 22k combo.
Attached the Eagle files. Enjoy!
steenoe said:Alcaid, is there any chance you could post your pcb layouts to scale and in black&white?
That would be cool Great work.
Steen.
OPA549 amps or the pre?
- Chip Amps
- OPA549 Gainclone Layout
