OPA548 and shutdown
A mistake. It works in noninverting mode. The circut works. I have -15 on the output, but I can't shut it down even then I soldered pin 7 to -20.
Ex-Moderator
Joined 2002
Hmmm.
Well, If you have two seperate secondaries on your transformer you could just use two +15 versions on dual bridges, that would get you working.
Other than that, drop a line to TI's tech support. When I had a query a couple of years ago they were very helpful.
