opa 2134 vs 2 opa627
Here is an example from a diyaudio member.
( calling herself a geek chick on headphone forums :clown: )
I'm no specialist, but here's what I think is a good read on decoupling/grounding OPAs:
http://www.analog.com/UploadedFiles/Application_Notes/135208865AN-202.pdf
IMO, or at least based on my ears, additional capacitance from V- to V+ does indeed make a positive difference sound quality wise, I usually use 10nF COG ceramic with good results (my ears/my preferences/my equipment) in this position - OPA V+/ V- pins. I think that good HF behaviour in this position is more important than raw capacitance (electolytic) - at least for high bandwith opamps, as long as you have decent decoupling on both rails.
This (from my master tinkerer POV) might also yield improvements SQ wise (using 4.7 nF silvered mica for rail-to-rail decoupling right on top of SMD OPAs).
Exactly to the point, iamwhoiam !
That test showed no difference between AP and BP versions, difference only being the DC values.
I got the BP versions at the same cost as the AP's, a lot of them.
I have been forcing opamps in class A for ages, because of the distinct difference in sound when fets are driven in class A.
Maybe a reason why, imho, the difference between B's and A's exists.
20years ago i started using the Burr Brown OP27, in those days people who favored OP27 over 5534's already were exotic.
Telling others that BBOP27's sounded much different than PMI OP27's gave you the look, BB OP27 were very hard to come by in those days.
Now people say OP27's are no good, 5534's are trash.
It has not been that long ago when i still saw $3000 preamps running on 5534/5532's.
imo, the proper way to drive fets is in class A.
Still, the majority seems to keep running their opamps in normal mode.
Carlos is very keen on the OPA627, so am i, i am very fond of the BurrBrown sound.
I havent tried by-passing on the pins yet, but if i do i dont think i need a scope to tell the difference.
Still, it would no hurt if an existing difference could be quantified.
Sorry, but I stumbling on your old post I couldn't resist to correct
First of all the OPA627 is a FET opamp by it's input stage, which is always in class A, and not by it's output stage which is BJT based.
The measured the output stage for my purpose, and it (the output stage, and so the whole opamp) IS class A at least to 1Veff @ 400R.
