Dear all,
I built DIY Jim Holtz speaker statement.
Some lately I found out that one side speaker (R) is louder than the other
This happens after my PA blown out.
The Right speaker seems still making a good sound but just feel dull
I did change the cable from left to right to eliminate whether my eq is the one that causing problem. the result is still the same.
How would I know that the speaker is broken (since still making nice sound just dull compare with the other)
Should I check the cross over?
tks
tks
Tony, can you download or play some pink noise through the speaker at a safe level and use your ears near the drivers to see if a midrange is not sounding on the bad side? Figure that out first and then we can work from there.
Also, you might like to check over at HTGuide Mission Possible forum as the Statement designers are regulars over there.
Greg
Greg
Greg
And place the speakers face-to-face at a spacing so you can put your head in between and feed both with the same signal.
Then you can tell where some sound is not coming from...which speaker exactly.
As noted above: at a safe level.
Its possible you have partly shorted the voice coil.
Check it with a DMM and compare with the good one.
I had two speakers connected to a valve amp that went faulty and one speaker went quiet and the other was fine. When I checked the DC resistance one had dropped a bit.
Can you tell me how to check with DMM?
tks. Sorry I am a newbee
