(one more) ALEPH P 1.7 clone
Hello,
With several people from Audiostereo forum we decided to build ALEPH P 1.7 clone.
I will use ERO 10uF caps for input and output. There is also place for BG N type 10uF and 47uF capacitors on the PCB. WM8816 chip will be responsible for volume control. I tried to locate power transistor in one line. Connected to one heatsink they will work in the same conditions.
Suggestions seen miles - this will be my first PASS LABS construction working in A class.
Mr. Pass thanks for sharing this project ;)
  • aleph_p_pcb.pdf
This is how PS board look. I don’t like GND track so there are few things to correct ;)
There are no pictures yet. This is just a project. I will order several of this boards so they should be ready in a couple of weeks. I can’t wait the results and sound of assembled preamplifier.
veteran said:
Hi Digi01. Your pcb is really nice too :)
I tried to reach compromise between power and ground tracks. As You can see they are connected in single point. But small MKT cap close to transistor may be useful ;)
Jleaman, to who this question is? :)
Ive send a schematic to digi to help me and work on a digital volume pot.. he doesnt seem interested so oh well..ill have to do it on my own.
Few more steps to end this construction ;) Transistors are matched. This blue resistors were made by Elpod (0.25 – 0.5W, 0.25%, 25ppm).
