OLG Phase vs Output Phase
What is the relation between OLG phase and Output phase?
Doing some simulations of my amp and using the Audioamp.asc example in LTSpice shows the OLG and phase margin seen in the first picture, second picture shows output of my amp by AC analysis, with completely different phase and no phase margin whatsoever.
How important is the output phase, should there be some phase margin there as well?
AX tech editor
Joined 2002
Are both open loop?
jan didden
Administrator
Joined 2004
I think your compensation needs work, the CL phase margin appears to be non-existent at gains and phase shift well above that required for oscillation. You really want about 60 degrees of margin at the 0dB intercept closed loop.
Introducing a first order roll-off (dominant pole) in the VAS at a couple of hundred kHz might do it, but without seeing the design it is hard to know.
This schematic.
Everything is ok and simulates well, with low distortion, just need to do some work on the CL phase margin and Im done. But it turns out to be quite hard and I really dont know what to do about it.
Your compensation network is undersized.
Increase C4 to 68pF, C8 to 270pf and R30 to 2.7K at least.
Im afraid it is not so simple, been playing around with different values for hours with no good result, OLG remains more or less excellent through it all with a phase margin of more than 60 degrees at all times. But the CL response is just crap no matter what combination I try. Offcourse I *CAN* get a good phase margin bur really destroys my THD-20, at 72 Volts peak-peak(around 80 Watt) and crap CL phase margin I get 0.003xx% THD, but with good phase margin(atleast 60 degrees) which requires some rather high cap values I get 0.05xx%
Here is simulation .ac result. It looks quite good for me. I changed TMC slightly.
For .ac OLG graf you have to take -V(a)/V(b), and I connected TMC resistor to the left side of the V6 to have TMC included in ac analisys. Phase margin is 70 degree, quite good.
OLG, CLG and schematic attached.
For .tran sim I will need more time as I have to change simulation a bit more.
dado
dado
So how did you do the ac analysis on CLG? What settings did you use?
Well, did some more simulation, increased the LTP current from 1mA to 4.5 mA and adjusted the TMC cap values.
See attached schematic. Resulted in the attached OLG and CLG plots.
THD-1 with 1 Watt out into an 8 Ohm load gives 0.000004% distortion, rising to 0.000043% distortion at 60 Watt. THD-20 with 1 Watt out into an 8 Ohm load gives 0.000121% distortio,n rising to 0.004675% at 60 Watt.
Clipping occurs at somewhere between 80-90 Watt into an 8 Ohm load
Not the perfect amp but I'm quite happy about the results. Some tweaking will probably be required along the way to get optimum performance but as it is now it should give quite good performance.
