have you seen the movies and do you understand now?
Yes I did see the movie but a step by step picture layout like this one below would be better so I can print it out and work with it.
http://seijs22.home.xs4all.nl/nathenry maten 2.jpg
i see what i can do
nice to hear they turned out well.I test both boxes today and they sound great real great. ErIc I need to find two 12" drivers that can play well like the celestion bx4085. Anyone looking for a good midbass try this design.THERE GREAT. I need two more.
wich 12 inch are you thinking off?
i see what i can do
these are some of the 12" driver i was thinking about using.
Dayton Audio PA310-8 12" Pro Woofer 295-032
RCF LF12G301 12" Woofer Speaker 294-844
Selenium 12WS600 12" 600W Woofer 264-391
Eminence Kappa Pro-12A 12" Cast Frame Driver 290-424
Eminence Definimax 4012HO 12" Driver 290-577
Goldwood GW-12090 12" Select Series PA Woofer 290-292
I dont know which one of these drivers match the celestion the closest 0r if the design have to change a little for one of these drivers to put out the same spl and frequency response.
Can you post the rcf sim.
How about these Eminence IMPERO 12A 12" High Power Driver Speaker 8 Ohm 1100 290-690
Celestion FTR12-4080HDX 12" Professional Speaker 1000W 294-2002 (same price as the Rcf) with more power.
Selenium 12MG1400 12" Woofer / Midbass Speaker 264-468 I think this one might be The one.
stan why not use the same 12" driver?
Celestion don't make the bx12 4085 no more. I wish they start making them again. Those are some good drivers.
start with the last image end with the first
Ok, Thank you Eric
The top and bottom section is not in your picture layout
black is rcf wirh 10 ltr rear chamber
grey is the celestion
These are going to be a monster together
- Old school 12" speaker for midbass.
